Are my intake spacers missing?
I am in the process of reinstalling the A/C in my 1987 911 Cabrio. I'm having trouble fitting in the A/C bracket show in the parts catalogue as part number 17. If tightened down, it will push against the injector. The parts catalogue shows a spacer under each intake port. I don't think I have them installed. This would raise up the intake housing and (presumably) provide the clearance necessary. The engine was rebuilt 22 years ago. Is removing the spacers some sort of performance mod? Reduced runner length?
Cheers and thanks.
1987 Carrera Cabriolet in Cassis Red Metallic
Old 12-08-2025, 04:36 PM
Difficult to see on your pic, but these spacers are partially buried into the shroud and not easy to see. The two gaskets #6 are also needed.
Are you sure you have all the hardware to mount the AC braket, such as the special washers #26?
Please show a wider pic of what is rubbing against the injectors. Can't figure it out.
Gilles
RoW 88 Carrera coupé
Old 12-09-2025, 01:25 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
The insulators sure do look to be missing.
1986 Targa Guards Red
2021 MT09 SP
Old 12-09-2025, 04:52 AM
If the spacers/insulators were missing, I'd expect to see some more of the bolt threads protruding through the hex nut, which I don't see... definitely hard to tell with that pic.
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 12-09-2025, 05:30 AM
Good point. Unless whoever deleted them also replaced the studs with shorter ones.
Gilles
Old 12-09-2025, 05:36 AM
Rosewood,
Could you post another picture that shows a better side view of the missing gaskets and spacer? Test and verify.
Tony
Old 12-09-2025, 06:45 AM
lake wales fla
I agree with others that if the insulators were missing you would have quite a bit of stud extending through the barrel nut.
On another note your spacer # 26 is upside down, the small shoulder points down.
Richard
Old 12-09-2025, 08:09 AM
The spacers need to be there to compensate for the shorter intakes on the Carrera heads versus the SC intake on the heads.
It’s easiest to pull the right side intake to see what the problem might be. Without the insulator I believe the the intake would crush the shroud.
Bruce
Old 12-09-2025, 08:53 AM
proporsche's Avatar
looking at your pic does not help much ...but most likely the spacers are there..
here look ....here
1985 911 with original 502 191 miles...808 198 km
Old 12-09-2025, 10:55 AM
Here is a shot of the injector to AC bracket clearance. As you can see, in stock form it is tight. And yes, I agree with the other posters, with shroud in place, once can't see the insulators plus the stud length issues with no insulators.
2021 MT09 SP
Old Yesterday, 07:41 AM
As Porscheyard said ^ your #26 spacers are upside down in the pic you posted, which would raise the bracket. Turn the spacers over so the small shoulder goes through the smaller hole in the shroud to lower the bracket.
Old Yesterday, 08:35 AM
proporsche's Avatar
yup could not see it the pic is too dark
to OP...Plus you can always twist the injector sideways
Ivan
Old Yesterday, 11:03 AM
Solved!
First of all, thank you to all who took time out of their day to respond, appreciated.
Yea, in hindsight, my pictures were pretty crappy, these are better.
As porschyard and trials935 have pointed out, I put the spacers in upside down. The small diameter faces down and the large diameter faces up. The parts diagram is wrong, as it shows them upside down. Also, the previous owner put them back according to the parts diagram (upside down) after removing the bracket. That agreed with the diagram in the parts book and had me convinced that it was small diameter facing up and large diameter facing down.
Makes sense now, the small diameter fits inside the recess of the shrouding, allowing the bracket to move lower, providing a tiny amount of clearance between bracket and injector.
I've included a picture of the barrel nut to head stud showing that the spacers are definitely there as there is (almost) no stud protruding into the barrel nut.
The A/C reinstall adventure continues...
Old Yesterday, 11:20 AM
