jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Another CIS question
A while ago in one of many 'impulsive' buys and with the (wrong) idea to replace the intake runners of my 2.4T with the ones from a 2.7 I bought a full CIS, the good news is that the airbox is a stainless steel one even with a pop-off valve.
While I'm in the middle of replacing engine seals and fuel lines I thought that will be a good time to replace the airbox.
After close examination the stainless steel one does not have the small tubes where the intake runners go
as the original does
Two questions:
- What are the small tubes for?
- Does it matter if the small tubes are there or not?
Thanks in advance.. regards
Jordi Riera
'84 930 (modified)
Old 07-13-2003, 11:49 AM
those tubes are part of the cold start enrichment system. intended to stop the backfire that destroys the air box. not sure if you need them, especially with a pop off valve
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 07-13-2003, 12:26 PM
Go Gators!
s2per's Avatar
I replaced an airbox in my 3.0 once and left out the extra (small) lines that your concerned about. The cold start circuit still worked fine (well, for Florida at least) and my thought was that the air flow was less obstructed with those lines gone.
Nice air box you got there--I was looking for an s/s one when I had to replace mine. Good luck.
Timothy Stoops
Air '62 356 B-‘86 911 Cab
H2O '12 Cayenne
Old 07-13-2003, 05:28 PM
drag racing the short bus
dd74's Avatar
Does anyone sell SS airboxes?
Doe anyone have any other photos? They look cool!
The Terror of Tiny Town
Old 07-13-2003, 05:55 PM
jriera's Avatar
Thanks guys.. I guess I have some work to do this week (change the old airbox for the new one while the engine still out)
dd74.. I can take more pictures if you want ... don't know the origin/manufacturer of this one or if anyone still sell them but the construction and the welding is very good. I do not expect any performance gains.. but rather the 'cool look' effect.
Regards
Jordi Riera
'84 930 (modified)
Old 07-13-2003, 06:55 PM
I would guess that was hom made but looks good> I would imagine that took a lot of time to make and at todays rates cost about $500 bucks give or take.
Ben
77 911 3.0
75 914-6 2.7
Old 07-13-2003, 07:33 PM
dd74's Avatar
Yes, Jordi, please take more photos if it won't inconvenience you. I like the look of stainless steel airboxes. I wouldn't expect any performance gain - just the look factor.
But if they are $500 a pop, or so, I don't know if it's entirely worth that much.
They're still cool.
Thanks.
Old 07-13-2003, 08:47 PM
