Super Moderator
cstreit's Avatar
A good set of used S calipers goes for $300-$400.
I have seen at least 5 different ones for sale in the last few months on the pelican for sale board and on rennlist.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-15-2003, 08:16 PM
Garrett's Avatar
You'll need new struts for S-calipers... don't forget...
Old 07-15-2003, 08:20 PM
jankemi's Avatar
Send a message via AIM to jankemi
Back to the queston:
"Where can I find this upgrade."
I bought stainless steel pistons for 'S' calipers for about $30/each at ZIms. http://www.***********
I'd assume that they have SS pistons for other calipers also.
--Mike
Old 07-15-2003, 08:38 PM
mkozikowski's Avatar
Thanks for all the info.
Good to know that for the caliper upgrade I will need strut upgrades also.
Old 07-16-2003, 06:30 AM
So Garrett, your telling me that a 73 S and a 73 T had entierly different struts? Are you sure it is not the later A calipers that have the 3.5 spacing, cause I have always been under the impression that the S and M had the same spacing and were directly interchangable. If not, I just lernt some stuff.
Oh and for the later calipers with the 3.5 inch spacing, it is not uncommon for guys to simply elongate one of the mounting holes (make it a slot) to mount the caliper on the early strut. So I'm pretty sure it can be done.....
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 07-16-2003, 06:48 AM
Bill Verburg's Avatar
All S and A caliper struts have the same 3.5" OC caliper bolt spacing. M struts are 3" OC as are the trailing arm mounts.
Bill Verburg
Old 07-16-2003, 07:04 AM
I'm learnt!
Old 07-16-2003, 08:53 AM
