3.6 conversion- which clutch?
Putting in a 3.6 vram into a 1980 SC. Been told the stock clutch can not take the added stress. Some suggest the Sacks Power clutch and others suggest Centerforce Dual Friction. Centerforce is more than twice the Sacks. Car is on the street with 6-8 DE events per year.
Opinions with experience are invited.
Thanks.
Old 06-18-2004, 01:48 PM
Bill Verburg's Avatar
Either will work fine
Bill Verburg
Old 06-18-2004, 01:59 PM
MuffinMan's Avatar
I just underwent the transformation, and I chose the centerforce clutch. I don't have a whole lot of time on it, but I've been to a few track events and a handful of autocrosses. I like the feel of it, and it's holding up grandly so far. I don't have long term experience, but I believe Bill Verburg is still using the same centerforce clutch installed in 1994 (?) with his 3.6 conversion.
Unfortunately, I have no direct comparison to the Sachs offering.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
bump
Old 06-19-2004, 04:40 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I don't have any time with a Centerforce, but I do know the OEM will not hold up while the Sachs Power Clutch works great. I do believe you get what you pay for, so the Centerforce should be the better based on price.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-19-2004, 05:29 AM
Irrationally exuberant
ChrisBennet's Avatar
Is the Centerforce the one that uses the little weights? I've seen them destroy a 3.2 flywheel and heard of one failing at a hillclimb. I'd go with a Sachs myself.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-19-2004, 05:58 AM
I bought my SC and immediatly replaced the worn out clutch with the Sachs option. I've got about 1500 miles on it so far and I really like it. The action is very smooth - granted, my machine is the stock 3.0 but I went with the Sachs because my wrench said it should be fine for any engine upgrade I chose in the future.
Mike
Old 06-19-2004, 06:12 AM
H20911's Avatar
sachs.
Old 06-19-2004, 07:59 AM
Jcon's Avatar
Don
Does this mean you've found your engine? Just finishing my conversion. You're gonna like it.
Jeff
Jeff C
76 912E 2.6L
Old 06-19-2004, 08:23 AM
Me like track days
Craig 930 RS's Avatar
Centerforce no longer uses the weighted clutch pack.
It appears they currently mill the portion where the pressure plate fingers rest - in order to create more holding pressure
Craig
@RS
http://forums.pelicanparts.com/memb...fo&userid=18005
Craig
@RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-19-2004, 12:07 PM
RETIRED
Joe Bob's Avatar
Sachs
2012 ML350 3.0 Turbo Diesel
Old 06-19-2004, 12:31 PM
POVI's Avatar
Hi ,
Im running a Sachs power clutch assy , with a lightened flywheel , asn 3.6 motor, 915 box .. no problems here after 1.5 years !
Joe
Old 06-20-2004, 06:00 PM
