911sc ignition/starter problem
I havent started my 80sc in 10 days, up until then everything had been fine, I turn the key and all i here is the fuel pump, i removed the battery and it was given a clean bill of health, cleaned the post's still nothing, i got under the car to check connections at the starter and found the wire to terminal 50 frayed badley, i fixed that problem with a new wire and connector yet the starter wont engage, thinking the starter gave up the ghost i took two screw drivers and jumped the starter terminals and it started right up. any ideas? is it my ignition switch?
If jumping the starter does the trick, but turning the key doesn't then that is a likely cause.
SCWDP- Shock and Awe Dept
or the solenoid. Do you have a Bentleys manual? It goes through the voltage checks to troubleshoot the starter system. Looks like you’ve got it nail down to two possibilities.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
I will check the voltages in the morning per the bentley manuel,if they check out im left with the ignition switch, it blows my mind how it has worked fine day in day out,i just left it sitting for 10 days and it just decides not to function anymore,tell me cars dont have personalities
