Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Inexpensive ways to ship an engine?
Hi all,
I've got a 400 lb. crated engine that needs to get from Kentucky to Colorado, in a reasonable amount of time. I've been quoted $560 so far, and 5 days travel time. I have to believe someone can do better than that out there. Any suggestions?
Zip codes are from 42086 to 80304. Thanks!
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 07-28-2003, 08:21 AM
andrew15's Avatar
Try www.YellowFreight.com
- call the 1 800 # and ask for the 'yes discount'
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 07-28-2003, 09:42 AM
Any of the larger trucking companies can handle it for you. Overnight Transportation, Roadway, FedEx Freight and host of others. You can also check with moving companies. Don't go with the cheapest just because they're cheap. Getting a motor delivered for $100 less and having it damaged doesn't do you any good. Also make sure you place insurance on the shipment as freight value is limited to a $'s per pound coverage unless you insure the shipment. Believe me the $ per pound will come no where near the value of your motor. Make sure you mark the shipment not to be top loaded. Also make sure you have a good crate and not just a cardboard box over the engine. If the cost of the shipment equates to about $1 per pound (not including insurance) you're in the right ballpark
Dan O
84' 3.2 Targa
Old 07-28-2003, 09:43 AM
chuckw951's Avatar
I used a company called Con-way to ship a 3.0 motor and a 2.0 motor.
https://www.con-way.com/default.asp
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 07-28-2003, 10:34 AM
Rennch on YouTube
rennch's Avatar
How much did you pay, chuck? And how far did it travel?
Michael O'Neal -
Old 07-28-2003, 10:35 AM
