Former Options Trader !!!
930 A/C Questions
My wrench tells me that the clutch on compressor of my 911 is frozen. He believes that enitre compressor needs to be replaced because of this. My question to the experts here is this: 1) does the entire compressor need to be replacee or can the clutch just be replaced? 2) whats the cost for a clutch only? and whats the cost for a full compresor and clutch? How much labor is expected?
3) are the compressors in the 930 and the 911 different?
The system has already been converted to R138
Thanks for the help.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 07-28-2003, 06:56 AM
Not Quite Banned
Thomas Owen's Avatar
What compressor do you have? If it is the 10P15C Nippo then you can replace the clutch only and the part should run in the $125-160 range. Labor to replace about 30 minutes. Compressor and clutch remanufactured will run around $200-250 for the compressor and use a new clutch. With the new compressor you probably need a new dryer and of course evac/recharge.
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 07-28-2003, 07:20 AM
jbryant's Avatar
I just took mine(compressor) off (1979 930). It worked fine. If you need it PM me.
01 996TT
2003 M5
1979 930 (sold)
BMW 1200 GS Adv&BMW 100/7
F350 Diesel
Old 07-28-2003, 08:53 AM
david914's Avatar
If the compressor itself is frozen, you need a new compressor, not a clutch. You may want to have your wrench clarify.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 07-28-2003, 09:18 AM
david, thanks i realize that... i am asking for prices and estimates from people here on both.
Old 07-28-2003, 09:21 AM
ruf-porsche's Avatar
Never hear of a clutch being frozen, clutch do go bad, but when they go bad, they usually don't engage the compressor. I think your mechanic meant to say the clutch won't turn so the compressor is frozen so you need a new compressor.
Little irony in terminolgy, the only time a 911 a/c is frozen is when the compressor is no good.
Old 07-28-2003, 09:34 AM
scottb's Avatar
I think Ruf is right. It sounds like you may have compressor "black death," where the compressor basically melts down. If that's the case, then the entire system will have to be flushed, and the compressor and receiver/drier replaced.
Contact Compressors International. As I recall, they charged me about $180 last year for an overhauled compressor and a clutch (exchange). (If your compressor has succumbed to "black death," you won't be able to exchange it, and you'll have to buy one outright.)
Good luck.
1984 Targa
Old 07-28-2003, 04:28 PM
