NGK Iridium Spark Plugs
Anyone have experience or thoughts about using the NGK Iridium plugs in an 84 Carrera.
Kevin 84 911 Carrera 71 911E Vintage Race Car 25 Ford Explorer ST 20 Subaru Crosstrek |
No experience, just thoughts. They would be an expensive substitute. Are you looking for more power? If so, I don't think you'll won't find any in this area.
Sherwood Lee http://members.rennlist.org/911pcars |
Friend of Warren
Waste of good money. You will get no more power than with the standard NGK plugs.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Using them right now in my '87. I was using Bosch Platinum+. Actually feel the Bosch was marginally a better performer and a lot less expensive. Most fell NGK or Bosch Copper core are the best performers. That's my next switch, NGK BP6ES.
I use the NGK BP6EY. The guy at NGK tech support told me to give them a try. They have a split electrode, they weren't any more expensive, so what the hell.
Paul
My ignition is retarded. |
Information Junky
Platinum .. .Iridium . .. I'm holding out for the plugs made from unobtainium.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Senior Member
Anything but kryptonite. I use copper plugs. I like NGK and Bosch. Trusted mechanics invariably recommend the simple copper plug. Besides, copper plugs contain no kryptonite. Can't be sure about the other ones.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Driving member
I know some people seem to be ok with split electrode plugs but I put some in my car last year and after about a week they started causing the car to miss so bad I couldn't drive it. They were bosch platinum. And yes they were the ones prescribed for my car.
After doing some research and asking around evidently there have been cases of people burning a head with these plugs. Just a word to the wise. These cars were engineered with certain things in mind and I think when you deviate from those at the least you are wasting money and the worst doing permanent damage. I went with the standard bosch at .99 each and the car ran great and still does.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Thanks everyone for your input, I'll stay with the old tried and true copper plugs.
Kevin
A gear head friend of mine explained the deal with platinuma and iridium plugs. Platinum takes less voltage to create a spark compared to copper and iridium takes less voltage than platinum. Is this enough to make a difference or just enough to burn cleaner. For those of you who need to pass emissions tests, (sucks to be you) it might be something to think about and investigate.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
Irrationally exuberant
I've heard from a shop owner friend of mine that the trouble with the Bosch Platinum's is that the sintered platinum electrode falls out. This is the $2 Bosch platinums, not the $20 one that some older 911's use.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Called one of the better known tuners in the Midwest and ordered several tune-up items from him. Received the package today and noticed the plugs sent are the NGK's Iridium.
For an '86 turbo, anyone know what gap these should be set to ? I'm thinking .028. |
i use them in my harley. it fouled bosch platinums eventually, but not these, yet.
Thanks for your reply ! Got 4 of 'em in tonight. Started assembling new Magnacore Plug wires into a new distributor cap-geez they seem to be a real bear to get the leads down into the respective slots and seated firmly !
Running Platinums in my 3.2, check them ocassionally and never had a problem.
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
I run them in my road racing shifter kart. They've either added power or changed my luck, but I couldn't see putting them in a street car, unless you just really needed to spend some money.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I believe the only advantage to platinum is that past a certain temperature it becomes a self cleaning metal. Hence the reason why the claim to go 100k miles without changing. But copper conducts electricity much better than platinum (or at least that what i remember from chemistry). Iridium i have no clue of, but then again if you want the best conducting metal, just have someone make gold plugs for you. Or go second best with silver. I like copper better myself and a tuner in san diego told me the same thing i've stated above.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
I tin' de gol an silvr wil melt maaan.................
The world out there is divided into bastards and suckers.......pick your side. |
Dept store Quartermaster
"if you want the best conducting metal, just have someone make gold plugs for you"
Actually this is not correct. Many people believe this because all kinds of high end electronics come with "Gold Plated Terminals". They do not do this because gold is such a great conductor of electricity, rather it is a good conductor that has great anti corrosion properties. Unless I am mistaken silver is one of the best conductors along with lead?(not sure on that one).
Cornpoppin' Pony Soldier |
Schleprock
Aren't the precious metal plugs more durable than the usual copper core plugs.
Meaning, they last longer than the coppers? Other than the longevity issue, I think it's been mentioned around here a number of times that the high dollar plugs don't provide any significant advantage? The spark plug issue is alot like the oil preference- buy whatever makes you happy?
Kevin L '86 Carrera "Larry" |
