Montana 911
thanks, when I contact them how do I explaing the fitting? Is it simply a high pressure fitting?
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Chances are they can reuse the undamaged half. They will then look in their parts for the replacement to the other (damaged) part and weld them together (if they do not have the complete part in stock). Here in the states, I did this to make the fitting to adapat a later fuel filter to my car. Cost here was $12for the new fitting and welding it to the usable half of my fitting.
Montana 911
thanks, I will take a look around.
So you are finally getting into it, hm? Good job. And always do the tranny and engine together for a drop. I don't understand how someone could think up this partial drop of the engine alone.
It's painfull enough to mate the tranny with the engine while both are out of the car. I don't even want to think about it with the tranny in the car. Today I threw in new torsion bars and adjustable spring plates into mine. 29 hollows and 21 solids. Also upgraded the front sway bar. Turbo tie rods and brackets for the rear sway bar are on its way from our host. It's finally handling a lot better. Once I get the shocks revalved and the rear torsion bar mounted it should be good for some track action. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Thread Tools | |
Rate This Thread | |
