Bill Verburg's Avatar
gearing
I've been playing w/ some ss illustrating the affect of gearing on available forward motivation(thrust). This was sparked by a not too recent discussion on Rennlist.
This chart shows a stock US 3.2 Carrera in blue, vs. a typical short geared 915 in the same car in red.
1st and 3rd are the same in both boxes.
yaxis is available forward thrust in lbs.
I find this fascinating because you can compare the effect of changing tires, gearing, or engines.
If you need to set up gearing for a particular track this stuff helps immeasurably.
Bill Verburg
Old 08-01-2003, 04:27 PM
Administrator
Jack Olsen's Avatar
Very cool.
Uh, I choose red.
Old 08-01-2003, 06:42 PM
Chuck Moreland's Avatar
Something doesn't seem right.
Red has the same thrust profile as blue, as expected, corresponding to the torque curve of the motor. It's just higher due the the reduction in ratio.
However, I expect the red curve to be shifted to the left in an amount proportional to the reduction in gearing. Instead they line right up.
Also, it appears that it is 1st and 3rd that are the same.
What am I missing?
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-01-2003, 09:12 PM
Chuck, Right you are! There is a shift I just picked the wrong inputs in the original chart. Which I have since ammended
Jack, You did chose the red(that's your trans)
Do you want one for your car as it sits? I haven't done a 964 engine yet. I just need to know what tires are in the back, and the all up weight if you want potential acceleration curves. As I said I did this for my car as it sits, fascinating stuff!(to me)
Bill Verburg
Old 08-02-2003, 04:48 AM
This one shows the shift more clearly. I wanted to see the effect of a different tire.
Bill Verburg
Old 08-02-2003, 04:59 AM
Administrator
Jack Olsen's Avatar
My car weighs 2390 pounds, gassed up and ready to go. Add my 160 pounds. Rear wheels are 315/35's
Old 08-02-2003, 10:57 AM
Ok I'll work on it. BFG KDW? I love rainy weekends
Bill Verburg
Old 08-02-2003, 11:03 AM
Ok Jack here it is, assumptions
  • 964RS hp and torque curve
  • No air resistance
  • 2590 lbs all up weight
Bill Verburg
Old 08-02-2003, 01:58 PM
Administrator
Jack Olsen's Avatar
Cool! Nice and close on the graph, which is how it feels when you're winding through the gears.
Old 08-02-2003, 05:14 PM
