SCWDP- Shock and Awe Dept
Where to get A/C system plugs
I need to remove my A/C compressor and engine lid condenser on my SC. I want to keep the system sound so I can reinstall the A/C at a latter so I need to properly plug the fittings.
Does anyone know what the best place to get the right plugs would be? I want to avoid removing everything and taking the parts to the hose shop and hope that they have the right ones after it’s already apart.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
You can buy flare fitting caps at the Home Depot. That will cap the compressor. They are 1/2 and 5/8 inch size caps. For the hose you need to find male plug, same size as the caps. Or you can buy a double male flare fitting and just buy a cap to cap the hose.
Thanks, Do you happen to know the actual sizes?
Doh! Thanks!
