"California Type Car" - C03 Option Code
Anybody familiar with the implications of this option code on a 3.2 Carrera?
Old 08-11-2003, 09:28 AM
Irrationally exuberant
ChrisBennet's Avatar
California cars had a jumper in the engine harness (Terminal 10). That terminal is used to alter the behavior of the DME.
Link to manual page
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-11-2003, 09:50 AM
So what does that mean in layman's terms? Is it something you can disconnect or alter to be more in line with the rest of the US? Does it relate to power or emissions?
Thanks.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 08-11-2003, 10:08 AM
Thanks.
I'm not sure how it differs.
-Chris
Old 08-11-2003, 10:21 AM
Thanks for the insight Chris...
Does anyone have a clue as to what these jumpers do?
Old 08-11-2003, 03:08 PM
Steve W's Avatar
Like Chris, I am not absolutely certain, but the terminal 10 connection at the DME, the two brown wires on the DME harness are connected together by a male/female electrical connector for California and Japanese cars. I believe its function is to further lean out the air fuel mixture, making the car more compliant with stricter California emissions regulations. This would most likely mean less fuel on acceleration when enrichment is needed. This is why California cars were rated at 200 hp with a factory 0-60 spec of 6.7, while 49 state cars were rated a little higher with a 0-60 of 6.1 seconds. If I were you, I would just disconnect the two wires if the are connected, and not worry about it anymore.
Old 08-11-2003, 04:51 PM
