canna change law physics
red-beard's Avatar
Zenith vs Weber
Can someone explain the differences between the Zenith and the Weber and any performance/maintenance issues of using a Zenith?
James
James
Red-beard for President, 2020
Old 08-08-2003, 05:50 AM
billwagnon's Avatar
It's my impression the Weber is more of a "standard" and is more finely adjustable/rebuildable.
But that's all I know. Honest.
Old 08-08-2003, 10:41 AM
red-beard's Avatar
Why did Porsche replace the Weber with the Zenith? The Zenith appears to have been used in 1970 to 1972. The Weber was used from 1965-1969.
I'm putting together a "spare" engine to use between my 1974 911 and 1970 914/6 while I successively rebuild those engines. I found a set of Zenith's for very reasonable money. Total cost for the linkage (new), manifold (New), Zenith, Carb rebuild kit and K&N air filters (New) is
$776.
James
James
Old 08-08-2003, 11:23 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I'm not really a carb man but I belive that they don't have any venturies other than the 27mm one that came with them. From what I've read they are pretty restrictive. Webers on the other hand have a large selection of venturies, emulsion tubes and jets where the zeniths do not. From what I've read the zeniths with 27mm venturies can only make about 160HP before they become the restriction in your engine.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 08-08-2003, 11:47 AM
I think that Webers are more suited to a race enviroment, but I prefer my Zeniths for the street. On Webers, the main jets and the air correction and emulsion tubes can be changed without leaking fuel onto your exhaust (big plus on the track). With Zeniths, you have to hold a cup under the side of the carb to change the main jets to "catch" the fuel leakage (takes more expensive track time). But, on the early Weber's you only had a 2-position accelerator pump, (either to lean or too rich). On Zeniths, you have adjustable accelerator pumps, although Weber did correct this on later models with adjustable pumps. I'am running Zeniths on a nicely built 2 liter, and there enough carb for the motor and I love them. Tens years ago nobody wanted Zeniths, I picked up what your looking @ (carbs, linkage, manfolds and k&n's) for 75 bucks!
Old 08-08-2003, 12:22 PM
red-beard's Avatar
The Zenith's were $100. The rest of the stuff was the costly adventure.
James
James
Old 08-08-2003, 12:46 PM
Randy Webb's Avatar
Weber tried to create a spare no expense carbureter.
Check BA's book for more info.
Old 08-08-2003, 01:35 PM
red-beard's Avatar
BA ?
James
Mr. T from the A team?
James
Old 08-08-2003, 01:37 PM
Weber, the ultimate driving machine carburetors.
Got four of them sitting atop my Ferrari. Hard to tune, but once they are dialed in, they are IN.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-08-2003, 01:39 PM
Two sizes of venturi are available for zeniths, 27.5mm and 28.5. I have two sets of zeniths and have a set of each.
I have just put a 165 hp Euro 2.7 in my 70T, with an early exhaust... so it should be around 175hp.
I Lathed out one set of venturis to 31mm (yes getting a bit thin in one spot but OK just) and rejetted the carb according to recommendations used for webbers. The engine goes very well, and does not appear to be leaning out at high revs in fifth.
I believe Motor meister can supply even larger venturis.
My zeniths have been great. Sure they arent webbers but at a tenth of the price, and they do the trick nicely on lower horsepower motors.
Stu W.
76 911 turbo.
79 911 SC.
Old 08-08-2003, 04:26 PM
BA = Bruce Anderson
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 08-08-2003, 04:31 PM
red-beard's Avatar
Well, the 2.2E is no barn burner. MM is supplying the gear to fit the Zeniths and to rebuild them. Again, my intent is to setup this 2.2E as a spare for my 914/6 2.2S and to initially run in my 1974 while I'm fixing the case studs, etc...
The Zenith Carb setup seemed to be a decent solution in place of trying to get the CIS working on the 2.2. Plus this will let me "drop" it into the 914/6 while I'm getting that baby redone.
James
James
Old 08-08-2003, 04:35 PM
red-beard's Avatar
Originally posted by DonNewton
BA = Bruce Anderson
Thanks!
James
Old 08-08-2003, 04:37 PM
jluetjen's Avatar
Uhhh -- now you lost me. First off none of the 2.2's ever came with CIS. And compared to the tuning of most (all?) of the later CIS cars, a 2.2E is a pretty hot little motor with a 7000 RPM readline. (Take THAT SCWDP!!!). Even with it's relatively small 2.2 liter capacity it made more HP (and a much better sound) then a 2.7 normal. If by chance you are refering to the 2.2E's stock MFI system, it's good for 10 more HP then you'll ever get with the carbs, and they're not that bad to get set-up right. If that is what you do have, this BBS and the associated technical links have the best MFI information around. Period.
If your 2.2E seems like a lackluster motor it most likely needs a good tune-up.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-08-2003, 05:23 PM
red-beard's Avatar
The CIS refers to the CIS in the 1974 with the 2.7 that needs serious attention.
If have not operated the 2.2 yet...working the fuel system right now.
James
James
Old 08-08-2003, 06:13 PM
I love my zeniths on my 74 2.7 I put 32mm venturis in it and bigger jets etc. wouldn't trade them for webers
Ben
77 911 3.0
75 914-6 2.7
Old 08-08-2003, 08:26 PM
Hi Ben,
You have a similar set up to me.
mine was a 77, 2.7
Out of interest, what mains, idles and air corrections did you use?
I have 130 mains, 60 idles and 185 air corrections.
Cheers
Stu W.
76 911 turbo.
79 911 SC.
Old 08-08-2003, 09:11 PM
Mine is about the same except mains I drilled until I came up with the best results. The drill size escapes me though.
Ben
Old 08-09-2003, 04:29 AM
There are two types of Zeniths, one type was sold in US only and has an extra enrichment circut for overrun conditions. The other sold in europe did not has this circut. Does anyone know if you can modify the USA type to the Europe version ?
I like them I drive them
Old 08-09-2003, 08:14 AM
Yes by removing the enrichment circuit altogether. I performed this on mine and they work great. My car starts well when cold much better then my dads 356sc with zeniths on it. I do have a sketch somewhere of how to do this if intrested let me know.
Ben
Old 08-09-2003, 10:33 AM
