Former Options Trader !!!
Pros and cons on 964 bottom motor cover?
Has anyone run their 964 with the bottom motor cover off for cooling? what are the pros and cons of doing this? Thanks
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
pros :
-less noise -cleaner engine cons : -heat -access for tuners ![]() On my ex-964 I did remove it... regards, Luc
Porsche 961 Le Mans'86 |
Friend of Warren
Isn't this a standard recomendation? I know Bruce Anderson and John Walker both recommend the removal for cooling purposes. The cover was only put there to reduce engine noise.
Kurt V No more Porsches, but a revolving number of motorcycles. |
thought it was for air flow too
I was under the impression that it was also part of the areodynamics package to aid airflow under the car? I was thinking bout a ducktail on one of these and was concerned about cooling
SCWDP- Shock and Awe Dept
Didn’t it also help the airflow under the engine in order to reduce rear end lift?
I would think that none of the reasons for it being there in the first place outweigh the main reason for taking it off – HEAT.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Mine's on. As much as I respect Bruce's opinion I respect the factory's more.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Friend of Warren
While it may reduce lift, the main reason was that in order to sell the car in Switzerland Porsche needed to lower the decibel level of the engine. The best they could come up with was the engine cover.
Have a look see on this topic here.
http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=82117
1991 964 C2 -SOLD - miss it everyday - ![]() 2009 Honda CRV 2007 Audi A4 Quattro - just a sweet personal car - 2000 Land Rover Disco II - lifted 2001 GMC Seirra 1500HD CREWCAB |
or here
http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=81762 under tray ad nauseum........
oh, and which oil should i use?.....
MBruns for President
I have (had) followed this closely - seems like there was a much higher incidence of issues in warmer states - commutting areas where there was an opportunity to sit in traffic on hot days -
BTW - I took mine off - when I had my C2 Targa -
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
undertray
i think it was mainly for the Noisereduction ,as well as the sidecovers killing the Valvecovergaskets and Valveguides by overheating the valvecovers/ Towers . As for the Cooling with the Ducktail , check this out !
![]() No problems at all with cooling ,it gets a little light over 150 Mph, but you get used to it . harald |
The BIGGEST problem with this question (and the reason it will continue to be asked) is that there are excellent justifications for taking it off and for leaving it on. I have heard about the noise limitations before and that seems plausible. I have also heard about the improved aerodynamics with it on, but I am not normally running in the 140+ mph range where this is supposedly most effective. I have taken the stance that Porsche engineers are way smarter than me, but I agree they have made some well-publicized mistakes. Pretty much can't argue with the protection it provides to the engine, but it does mask some oil leaks and makes engine work more difficult.
I can't find the thread any more, but I have also read that it was effective in maintaining a level of consistency in engine cool-down which was said to be very important, but I never knew whether this was one man's opinion or whether it was based on sound engineering logic. I have found that my 964 runs pretty cool, but I have never Auto-X'd the car so I don't know what the temps might do during runs, or while idling between runs. Might get hot then... Bottom line, I asked my local wrench, and he said leave it on. I have so far. But that doesn't mean I am not going to ask another local wrench for his opinion, or stop reading the posts when this question is asked again in the future. Tom
Ain't life grand? |
i modified an original tray for my 993. It offers some protection, some noise suppression, some cooling, and some aerodynamics.
When it is really hot out, I leave it off. If I have to do some cold Canadian driving, i will put the unaltered tray back on. ![]() ![]() ![]() max
max |
Take it off,..........
![]() ![]() As someone in the Porsche business its a "pay me now, or pay me later" situation. Speaking only for myself, I take no satisfaction in doing permature valve jobs/overhauls from worn guides and terminal oil leaks, and these undertrays are the leading cause here. Porsche installed them for noise supression to comply with Swiss noise regulations. These REALLY restrict cooling airflow through the cylinders, heads, and case.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Schleprock
That is some darn nice craftsmanship there Max.
Well done!
Kevin L '86 Carrera "Larry" |
