I've changed the oil, air filter, fuel filter and the plugs on the passenger side of my 930. Now it looks like my day project might have gotten longer. I can't even see the plugs on the driver's side of the car. Any tips before I before I begin removing the various parts and hoses to allow access to the driver's side plugs? Any help is appreciated.
Ken 1980 930 |
Ken, intercooler at least has to come off. You may also find it easier removing hoses of the air pump and check valve, can't quite remember on this latter because I currently don't have them installed since I installed my Fabspeed muffler. Michael
Mike, I have the intercooler off. Although my car is a 1980 930, the motor is actually out of a '78. The original owner (I'm the 3rd) blew the motor up and replaced it with a '78 US 3.3. I see what appears to be a smog pump and other related equipment. Can I remove all of this (permanently) without adverse results? Also, the "smog pump" does not have belt attached to it. I can feel the pully on the back of the pump, but no belt.
Ken 1980 930 Last edited by engken; 08-17-2003 at 11:04 AM.. |
Ken, just did 5 days ago, plug change on my 930. Michael is correct on intercooler removal, and I took the air cleaner box off as well; gave me just a little more room. Above all, have patience ! Actually I found the left side plugs harder to replace than remove, especially the lower left one. Enjoy !
Thanks Mike. I appreciate the advice. I ended up taking out the smog pump and associated hoses. I will keep them for the next two years until my next smog check. Hope to see you at a PCA event.
Ken 1980 930 |
