Shift Light wiring help!!!
All,, has anyone wired in an Autometer shift light? I need to put one in my '87 Carrera and wanted to find out where I run the signal wire to. Thanks in advance for the help!!
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 08-18-2003, 03:59 PM
Bump...
Ayrton Senna
1993 964 RS
Old 08-18-2003, 08:07 PM
Somewhere in the Midwest
MotoSook's Avatar
I was looking into this for my car, and did a search. Although I did not saw any of the articles, I bet you can find them if you run a search on the net. I recall an article specific to the Autometer light. Others were simple and hooked onto the coil terminal with a selectable shift point. Seems modern electronics makes these very simple.
Good luck.
Old 08-18-2003, 08:18 PM
CamB's Avatar
Do the instructions say something like "hook the autometer signal wire to the tach wire".
Tach wire is on the back of the tach.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 08-18-2003, 08:27 PM
304065's Avatar
James,
I bought an MSD "RPM Activated Switch" that takes one of their electronic "pills." The instructions are comprehensive.
Do you have one of these, or does your switch hook directly to the tach wire (purple?)
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-18-2003, 09:26 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Shift light
First off, do you have an MSD or Crane Ignition system?
If so do the following:
You will have three wires on the shift light to connect. One for 12V(red). One for Ground(black) and one for connecting the tach (green).
The green wire will connect to the tach output on your MSD or the Greeb wire on your crane Unit. If your MSD does not have the tach output on the side of the unit, check to see if you have the Green wire like the crane system. If so use that one.
Are you running a after market tach as well? If you are, connect the Green wire to the same wire that you connected the tach to. That will operate both. In some cases the tach may have a wire specifaclly for the Shift light.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 08-18-2003, 09:38 PM
