spark plugs and tyres for my 2.7 RS
Hi
I'm building a RS replica (2.4S based), what shall i use for spark plugs ? what kind of tyres (215/60/15, 195/65/15) shall i use for street/track use ?
many thanks
best regards
Philippe
Old 08-20-2003, 01:40 PM
Platinum Member
dad911's Avatar
With RS flares, you should be able to run 225 fronts & 245 rears easily. Perhaps larger, with custom wheels/offsets.
Old 08-20-2003, 01:50 PM
spark plugs ?
There are 215/60 actually on the rear and the same on the front (??!!)
i believe the correct size was 215/60 rear
185/70 front, right ?
i was told i should use platinum spark plugs for a 2.7 MFI ?
regards
philippe
Old 08-21-2003, 02:40 PM
Early_S_Man's Avatar
Porsche Crest
Phillipe,
Same plug as works in a 2.4S will work in a 2.7RS ... depends on conditions it will be used under. A good starting point would be NGK B8-ES.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-21-2003, 02:49 PM
and for the tyres ?
Many thanks
and what about the tyres ?
Philippe
Old 08-22-2003, 02:26 PM
