spark plugs and tyres for my 2.7 RS
Hi
I'm building a RS replica (2.4S based), what shall i use for spark plugs ? what kind of tyres (215/60/15, 195/65/15) shall i use for street/track use ? many thanks best regards Philippe |
Platinum Member
With RS flares, you should be able to run 225 fronts & 245 rears easily. Perhaps larger, with custom wheels/offsets.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
spark plugs ?
There are 215/60 actually on the rear and the same on the front (??!!) i believe the correct size was 215/60 rear 185/70 front, right ? i was told i should use platinum spark plugs for a 2.7 MFI ? regards philippe |
Phillipe,
Same plug as works in a 2.4S will work in a 2.7RS ... depends on conditions it will be used under. A good starting point would be NGK B8-ES.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
and for the tyres ?
Many thanks
and what about the tyres ? Philippe |
