developed noise on the way into work
Hi guys. So having sorted out my intermittent fuel pumps as having to do with the yellow relay, I took the car on my 45 mile communte. And I developed a moaning sound that was discernible through the steering wheel as well. The sound is difficult to pinpoint becasue there is the whole wind-noise thing going on too. If I lightly tap the brakes, or jerk the steering wheel left or right, it disappears... but comes back momentarily. Any ideas on what parts to order?
Ken
1986 930 2016 R1200RS
Old 08-25-2003, 08:36 AM
Givin' a bump to help you out.
I have no clue to your noise.... You should get the front end up on jack stands and see if maybe it's a wheel bearing or brake hanging up.
Good luck,
Jeff
Old 08-25-2003, 10:34 AM
Friend of Warren
Two most obvious places to check would be a wheel bearing or a stuck caliper piston.
Kurt V
Old 08-25-2003, 10:39 AM
gary-o's Avatar
A moaning sound can be contributed to a wheel bearing going bad. Most likely a front one as the steering will affect the sound.
Regards,
Gary
Old 08-25-2003, 10:41 AM
Thanks for the suggestions. Interestingly our PP host does not carry the 930 front caliper rebuilds. As far as I know the front bearings are original, and I changed the rear ones over the winter (whata*****, BTW). The car does sit for extended periods, so it still could be either bearings or stuck caliper. The fact that it quiets w/ a tap on the brakes tends to suggest caliper over bearings, doesn't it?
Ken
Old 08-25-2003, 12:34 PM
