Senior Member
Superman's Avatar
Seat Belt Rewebbing
There is a guy out there who is as cheap and stupid as I am. A guy who rewebs seat belts for our cars was nice enough to send me a couple of strips of the proper webbing (unique width), with a loop sewn in the end, ready for installation into the retracting mechanism. I have a couple of spare mechanisms that are not pressed together, but rather are held together with screws, so I should be able to take them apart.
Obviously, there is a spring in there. Does anyone know enough about what these things look like on the inside to advise me how to disassemble the mechanism so that the parts do not fly out, and so that I will be able to reassemble it with the correct amount of spring preload?
Mocha 1978 911SC. "Coco"
Old 08-17-2003, 02:07 PM
I had the rear panel off with the belt re-winder.. so I somehow jammed the belt into the winder and tried to open it up to fix it..
KaBoom. not sure what to do now? that spring must be 25ft long
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2003, 03:37 PM
Senior Member
Superman's Avatar
Noah, there's a guy, in California of course, who rewebs them for a price. I'l have to look in the mags. I saw his ad in a magazine. I've had it a year or so. Life got in the way. I'll find his name and send you a PM or something. BTW, I just noticed how my remark sounds. He's probably thrifty like me, but he's probably not nearly as stupid. didn't mean that.
Old 08-17-2003, 08:56 PM
Senior Member
Superman's Avatar
Bump.
Old 08-18-2003, 09:28 AM
Noel's Avatar
I just replaced my driver's belt with a new Porsche part. I'll check to see if I through the old one out during my move. If not, I can take it apart and shoot some photos.
Noel
Old 08-18-2003, 09:42 AM
Senior Member
Superman's Avatar
Thanks. I'm not surprized by Ron's input. I'd expect the spring to be a very long unit. I wonder if there's a way to slip the new webbing onto a center shaft without releasing the spring.
Old 08-18-2003, 09:53 AM
AirCooledExcellence's Avatar
I tracked down a re-webbing firm in the UK, He asked me what car it was and how old the belt is, when I told him he said he wouldn't do it because the mechinism wears out and could become dangerous.
New Porsche belt cost about $150 and took about 1 hour to fit.
Cheers
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 08-18-2003, 11:57 AM
I just bought generic black retractable belt units from these folks:
http://www.andoauto.com/seat_belts.htm
The male belt connector will have to be removed and replaced with the Porsche one off my original belts, but hey, these are only $55 ea. and there's no messing with the internals of the retractor or its spring as with rewebbing.
Eric Purdy
Old 08-18-2003, 12:03 PM
I replaced the webbing on mine. Not intentional though. I had both sides go or I should say become lunch for a mouse.
So I ordered two used ones from some place out west and when I got them only one reel was usable. The other clicked and wouldn't retract so I had to swap the reels. I pulled the belt all the way out and shoved a small screwdriver in the slot. Then I worked the belt out enough to pull the small bar out. This lets you pull the belt out of the reel but getting the new one in is a pita. Put the bar back in the new one and let the screwdriver out to wind it up and thats it. Just a real big pain to do. Whatever you do, don't let the reel wind up without the belt on it.
Old 08-18-2003, 12:11 PM
Seldom Seen Member
Burnin' oil's Avatar
Superman,
I took my retractors apart for kicks, thinking that I could improve the retraction force (which I couldn't). If you remove the screws, carefully pull the sides apart and slip your finger in between the halves, you might be able to hold the spring in place. If you don't do it properly, the spring will become a rat's nest in under one second. Fortunately, it isn't too difficult to untangle the mess and rewind the spring, which I ended up doing a number of times . . . Just be careful that the spring doesn't rip your fingers off.
Why do things that happen to white trash always happen to me?
Got nachos?
Old 08-18-2003, 01:16 PM
Irrationally exuberant
ChrisBennet's Avatar
Professionally Engineered Products (PEP) is the only German "seatbelt guy" I know of. I got my belts from him many years ago.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-18-2003, 01:18 PM
Seldom Seen Member
EWPurdy,
Which belts did you order from Andoauto? Thanks.
Got nachos?
Old 08-18-2003, 01:20 PM
BO:
WS18B - Three point retractable in black without the female end.
Eric
Eric Purdy
Old 08-18-2003, 02:14 PM
Hilbilly Deluxe
emcon5's Avatar
Whatever you do, wear safety glasses.
Tom
82 911SC Coupe
GTI Cup #43
Old 08-18-2003, 02:31 PM
Car Junkie
I bought mine from PEP for $140/ea. All new retractor, webbing and "male" end. I looked at having them re-webbed, but the cost/benefit just wasn't there. I'd rather have the piece of mind of new parts. It took maybe 45 minutes to install both front belts.
Cheers,
Brad
'83 SC Coupe
Old 08-18-2003, 02:37 PM
Senior Member
Superman's Avatar
Thanks to all. Keep the comments coming if you have more. Here's a tip I can offer: Do not forget the plastic parts that hold the webbing proper as it slides through the bracket on the A-pillar. With the plastic pieces missing, the webbing will get eaten by the stress of sliding across the metal bracket cockeyed. And you'll need new belts.
Old 08-18-2003, 03:53 PM
I need to buy good used belts and retractors
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-18-2003, 04:08 PM
I too tried to open the retractor mechanisim to increase the tension. I assumed there was a long clock spring inside so I was very cautious but it still exploded in my face--fortunately I was not injured. I also tried to untangle it and reload it into the housiing to no avail--It just wouldn't work smoothly.
I gave up after 3 hours and 10 sore fingers and surrendered to: http://www.peparts.com
They fixed me up by selling me a new retractor and rewebbing using my original buckles. It was around 200 bucks--not cheap--but I was reluctant to use my old fraying belt on the new retractor. Oh, BTW this was on my 73.5
Regards and good luck
Old 08-18-2003, 04:27 PM
You do not have permissi
john70t's Avatar
Saftey glasses, a couple big hose clamps/perpendicular visegrips and a bit of luck(?). Sounds nofun.
Old 08-18-2003, 08:26 PM
Glasgow 911SC's Avatar
Eric (EWpurdy)
How did you attach the old male connector to the new blet without cutting th webbing? I bought new belts but the female part looks stupid (on a long stalk instead of flat bar) and would like to just use te new mechanism and belt.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 08-19-2003, 04:10 AM
