UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
Insane temp problem...FOUND & FIXED!
I can feel my hair growing back by the minute! For those who've been reading about my saga, you know I've stopped at nothing short of an engine teardown. I did pull it out though and did everything I could think of to resolve it. Well, short answer is that when I bought my car, the o2 sensor was disconnected and the light was beaming. I reset the light and decided to replaced the sensor. Went to Checker Auto and bought the Bosch one for my car...or so I was told. Bastards gave me the wrong one! Talked with my neighbor friend and asked him if it was possible that the wrong sensor could do this. He said "yep" so I disconnected it and had my friend richen my mixture a bit to compensate. Drove it today in mid-80 weather, jumping on the pedal through town and it never topped 215. The o2 sensor had been on my mind for weeks and I kick myself for not pulling it sooner. Now, I'm just going to drive her
Matt
'82 911SC Targa!
Old 09-01-2003, 06:25 PM
Mark Wilson
Guest
Posts: n/a
Congrats. Good job!!!!
Old 09-01-2003, 06:30 PM
1982911sc's Avatar
Great news!!! You must feel sooo good right now! So, did you pull the O2 all together or did you replace it with the correct one. I am tempted to pull mine and see if it runs better/faster. Thoughts?
944 TURBO!!!!
1982 911 SC Targa (loved but sold!)
2005 Cobalt SS (0-60 in 6.1!!)
2003 BMW 325i ex got in divorce
1969 912 Coupe (sold)
PCA Member
Old 09-01-2003, 06:33 PM
I didnt pull it, I just unplugged it. Some places need it for emissions. Also, if you do disconnect it, it's been recommended on this board to set the CO to 3.5% (I believe).
Dont keep telling me I need a BIGGER cooler!
Matt
'82 911SC Targa!
Old 09-01-2003, 06:36 PM
Team California
speeder's Avatar
That's bizarre! From what I've understood, the sensor is more of a 'fine tune', and only has ANY effect if mixture is correct in the first place. Otherwise, the system will be in open or closed loop all of the time(?) Your car was simply running extremely lean all of this time, had you ever checked the mixture through all of this?
At any rate, glad that you found it! There is mixed opinon around here, but I say put the right sensor in and set it right. It's a great system when working properly. Happy driving!
Denis
Old 09-01-2003, 06:53 PM
ruf-porsche's Avatar
UTKarmann_Ghia
Congradulation, I follow your saga and happy to learn that you finally found the cause of your over heating.
So the cause was a too lean condition due to a faulty 02 sensor?
Old 09-01-2003, 07:23 PM
Pat S's Avatar
Yeah!!!
I'm glad the Porsche gods saw it fit to place an expert mech so close to you
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 09-01-2003, 07:52 PM
Whelp, that would be my guess that it mustve been running very lean. I did have it checked out by the local wrench, but whenever he set it my engine would lean surge at idle. He said it was good, but obviously not. I too was under the impression that the o2 sensor could not have been a serious issue, but I drove around for the better part of an hour today and she was STUCK at 215. Another couple of hot days and I'll claim victory. I still dont believe it, so I'm being a bit skeptical, but man I've run the snot outa her and she's stayin cooooool
Here's to all the guys who gave me good, heck any, advice!
Matt
'82 911SC Targa!
Old 09-01-2003, 08:59 PM
Type911's Avatar
Matt,
Glad that you finally solved the dreaded temp. issue !
What % did you set the co, 3.50% ? How is the car running & starting now that it is set richer?
-Chris
Old 09-02-2003, 05:43 AM
Friend of Warren
Whaa hoo!!!! I've been following this from you first post and I'm glad to see you got it resolved.
Kurt V
Old 09-02-2003, 06:16 AM
I have been following your posts and am glad you finally seem to have it sorted out!
2009 997.2 C2S
Old 09-02-2003, 06:32 AM
Man, I've been driving like a crazy man the past couple of days. What a relief to not have to worry about my temps. No more driving like grandma for me!
Type911, I'm not sure what the co is set to right now. Had my neighbor adjust it and we didnt have a gauge to verify it. It was set to 1.5% before (o2 disconnected) and we turned the allen about 10 minutes in the richen direction. Smog here is not that stringent, but I'd like to set it at 3.5% when I get a chance. My guess is that she's at least 3% but that's just a guess. She idles great (no more lean surging either) and has always started and run well.
Oh! My friend also mentioned that I wasn't getting full throttle either. I adjusted the throttle linkage too and it feels like I've got about an inch more pedal now.
Matt
'82 911SC Targa!
Old 09-02-2003, 06:35 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Hmmm, glad to hear you fixed your issue. I may be wrong but i believe most of the SC's on the board have disconnected the o2 sensor anyhow.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-02-2003, 06:45 AM
That's true, it seems that the disconnection of the o2 sensor for the SCs is common place. But I have not yet heard of them causing this kindof problem! Believe me, that sucker is NEVER getting hooked up again!
Matt
'82 911SC Targa!
Old 09-02-2003, 07:13 AM
Irrationally exuberant
ChrisBennet's Avatar
I find it difficult to believe that the wrong O2 sensor could cause this problem. AFIK, they all produce the same output.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-02-2003, 07:24 AM
Slumlord
Porsche_monkey's Avatar
I agree with Chris, the majority of O2 sensors are heated or unheated, there are very few with a different output voltage. My guess is your closed loop control system does not work and you are running too lean with the O2 sensor connected. I think you might be premature in blaming Checker Auto.
You can easily measure the O2 sensor voltage output to verify its operation...
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 09-02-2003, 07:33 AM
Cool
Wonderful that you found the problem, I hope.
I'd be interested in the CHT & EGT that would cause that hot issue
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-02-2003, 07:36 AM
1fastredsc's Avatar
Possibly that switch on the throttle that disengages the closed loop system under conditions of wide open throttle might not be working.
2007 Mazda 3 hatch
Old 09-02-2003, 07:42 AM
Early_S_Man's Avatar
Porsche Crest
Matt,
Glad to hear of your progress!
Sounds like the OXS control module is malfunctioning. I doubt if a generic O2 sensor could cause the overheating ... unless miswired! If a low-impedance load was placed on the O2 sensor ... it was probably damaged or destroyed. Even the load of a conventional analog VOM can burn out the O2 sensor! That is why a DMM with greater thean 10-megOhm input impedance is always specified for testing O2 sensors.
It also sounds like your mechanic that took some mixture readings [OK or inconclusive, as I recall] either misread or misinterpreted the results!!!
Your goal of 3.5% CO is probably a reasonable goal.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-02-2003, 09:50 AM
Steve W's Avatar
Seems true though - disconnecting the O2 sensor typically makes your car run richer, which as a result, cooler. I know when I disconnect mine, my oil temps are at least 15 degrees cooler.
Old 09-02-2003, 09:54 AM
