thermal reactors+picture
hi
does anyone have a picture of a thermal reactor exhaust system. i searched this site and could not locate any pictures. i would send one of our engine but my camera batteries died. i am concerned that after a rebuild a few years ago with inserts, valve guides, oil fed chain tensioners etc. that the po's did not replace the thermal reactor muffler system. the system on our car, has the exhaust pipes dropping directly into a heat exchanger and at the front of each exchanger the 3 exhaust pipes the merge into 1 pipe that goes into a 2 foot long cannister type of premuffler and then to the muffler. we are not sure if this is a thermal reactor type of not. thanks gary
1975 911S Targa Silver Anniversary Edition |
It sounds as if you may have the dreaded thermal reactors. Get on the Pelican Parts catalog for your year car, pick the exhaust category, then click on the thermal reactors. A picture of the reactors and exhaust system is located there. IF you get lost emial me and I'll go out to the garage and take a pic of a reactor. If you have them and want to replace them I think I have a good set of thick flange thermal reactor replacements in the garage also. Let me know.
Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
thank al
ill check that out...though i was looking at the parts and saw an 88 carrera hex and it looks like that. gary
Can't follow all your description. Exhaust gas comes down out of the head exhaust ports and through three flanged tubes leading into the ~3.5" diameter "log" section of the thermactor which hangs under the heads running front to back. Exhaust exits the thermactor laterally to the L and R via one tube into the long exhaust heater exchangers. Not enough daylight to take photos, but post again if the PP diagrams and this doesn't help.
'76 2.7-->3.2 |
These are TRs. If you have them, they will match these parts. Exchangers look totally different.
993 |
Here you go, a thermactor ...
The worst 911 exhaust system ever made . . .
thanks
i do not have those type. i have this type of system...i guess the builder did it right. What is the round type of muffler? gary
That's a later system, maybe from a Carrera. It's good.
993 |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
