2.2E spec. questions..
Was the 2.2L ever installed in 1973 911's? I thought the 2.4L was the only displacement that year?
What HP did the 2.2L E spec provide. An engine I am looking at, is stated to be a '73 2.2E with MFI.
Thanks for your help!
Chris
Old 09-12-2003, 10:27 PM
2.2E was used in '70 and '71. It is NOT the correct motor for a '73. HP rating of a 2.2E is 155.
Old 09-12-2003, 10:30 PM
Hilbilly Deluxe
emcon5's Avatar
The engine number will tell you what it started life as.
A 911E engine number should be
62X yyyy
6 for 6 cylinder, 2 for 911E (911T could be 61 or 65, 911S is 63)
the number at X is the year,
9=69 (2.0 Liter)
0=70, 1=71 (2.2 Liter)
2=72, 3=73. (2.4 Liter)
yyyy is the sequential serial number.
Hope this helps,
Tom
82 911SC Coupe
GTI Cup #43
Old 09-12-2003, 11:01 PM
thanks guys for the info! I will ask the seller the engine number and the engine type number.
Thanks again!
Old 09-13-2003, 10:19 AM
This looks to be a 1971 2.2. I dont think this case would have piston squirters? Prolly a 3R case?
Not sure what this engine would be worth since one had to assume it would need rebuilding.
your thoughts?
Old 09-13-2003, 11:33 AM
Stressed Member
Scott Clarke's Avatar
A '71 should have piston squirters.
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 09-13-2003, 02:38 PM
I would think it is probably worth $1000 if it is in need of a rebuild and the MFI is intact.
Old 09-13-2003, 03:26 PM
