rickeolis's Avatar
Porsche Crest Pertronix schematic?
I have a newer engine with a Pertronix igniter in it, and I don't know the correct way to wire it in, HELP!!
1969 911T car with 1975 'S' engine 2.7 liter...
(Smitty do you recall that?)
-Rickeolis-
1986 Corvette
Old 09-12-2003, 11:29 AM
nigel911's Avatar
Try a 'pertronix' search on the board...
I have been where you are and know how frustrating it is. I have an earlier car which uses a different part, I do not know if the wiring is the same. Don't want to give you a bum steer and destroy your unit.If it makes you feel any better, once fitted they work a treat.
Old 09-12-2003, 11:55 AM
rickeolis's Avatar
Porsche Crest Pertronix good... Points bad... Ugghh...
I hear the same things from others, I really want to use it, but between the 3 wiring situations, I need to get it right.
Thanks for the advise, I'm searching...
-Rickeolis-
1986 Corvette
Old 09-12-2003, 12:05 PM
47silver's Avatar
do a search here you will find some good info. if i remember (we did this in april or may 03 and it is easy to install and works great.. the red wire goes to the rear fuse box on the 2nd fuse terminal. the black? goes to ground and the white? goes to the cd box or msd box an dto the tachometer.
1975 911S Targa
Silver Anniversary Edition
Old 09-14-2003, 07:03 PM
rickeolis's Avatar
Porsche Crest
OK, I am seeing that the red wire goes to a positve 12V (+) power supply line that comes on with the ignition in the run position, right??
The other wires are still in the wire loom and are correctly set up because I have seen the engine run before, but the red wire came undone during the conversion.
I'll use an inline fuse, rated at ???
-Rickeolis-
1986 Corvette
Old 09-15-2003, 08:20 PM
rickeolis's Avatar
Bump-
-Rickeolis-
1986 Corvette
Old 09-16-2003, 11:59 AM
CHILI's Avatar
Rickeolis,
I have the instructions/scematic that came with my Pertronix at home. If you want to e-mail me with a fax # I can fax it to you tomorrow. Sorry, I lent my scanner out to a buddy and haven't asked for it back yet, or I'd post it tonight.
You can e-mail me at chad.bowser@northgate.com if you have a fax #. Otherwise a search or maybe give them a call? I know they are in San Dimas CA, on Arrow Highway. I know, I saw the address on the box and saw the building the other day
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 09-16-2003, 01:18 PM
47silver's Avatar
rickeolis
just connect the red wire to the number 2 fuse on the rear fuse box.
gary
1975 911S Targa
Old 09-16-2003, 04:30 PM
