Wet driver window
Washed my 86 carrera and then then parked in garage. Two days later, had car out and when I put windows back up, my driver side window was wet on outside; passenger was dry.
I am assuming there are drain holes that must be clogged but beforeI take door panel off wanted to if others have experienced the same. Thanks Chris |
Diss Member
The water is coming from the weather stripping being soaked. Even if the drain holes were plugged, the window doesn't go far enough down to get wet that way. If anyone knows of a way to make the weather stripping so it is "water repellent" I would like to know. It bugs me to keep having to dry the windows over and over.
Wayn
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
My car does the exact same thing. Dr.side wet, never the pass side. I think the door panel has to be taken off and the plastic sheet under the panel adjusted. One of my things to do and soon as the rainy season is starting here
86 911 carrera targa 83 911 sc targa, totalled 01.21.13 end of an error. |
New window "squeegees" should help, if not take care of the problem. Easy and cheap to replace. About $6 a side if memory serves.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
The real problem is this "Washed my 86 carrera and then then parked in garage. "
Better to take the car for a nice long spin (not literally!) so all the hidden crevices will dry out and NOT RUST. it's an old 356 trick but will help the galvanic cars too. |
even with new seals you still get water down there (check the edges...it isn't a water tight fit). As a stop gap I put some armorall on my old squeegee...that seemed to help a bit.
Thread Tools | |
Rate This Thread | |
