Tie down hooks
I ordered a nice set of tie downs for my 911 from a fellow Pelikanite this spring, need another set for the 73. These are the nice red ones that bolt on to the shock absorber mount (rear) and are really nice for quickly loading and attaching tie downs on a trailer. Anybody recall the website for these?
Richard Lane 1978 911SC 1973 "Clean" RS clone |
Here ya go...
Doug 1964 356C - "Olivia" 1968 912 - Slate Grey |
Thanks Doug!
Does your 73 have the attachment hok (or whatever) up front? These rear ones are one hell of a lot easier than trying to thread straps thru brake dust and grease ..NOT thru brake lines ..you know the drill...
You're tellin me...
I do have the tow hook up front, but I would never use that to strap to. I don't trust its strength, and I think that it would put my straps at too great an angle.
I have seen some Weltmiester units that mount under the front A arm mounting points, but they were $100 for the pair, kinda rediculous. Not to mention that my car is so low already, that these things would become a hazard. So I'm still looking for the right answer...
I've seen a lot of guys use a ring welded to an old wheel lug - you place one on each wheel and voila.
Cheers - Ryan
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Ryan..ever seen those available commercially?I am pretty challenged when it comes to engineering such things. Wouldn'y have a drawing of these I could take to a friendly welding shop would you?
skip shirley makes the ring/steel lug holders- he advertises in excellence and pano. i've seen plenty of people use them- i am not so certain of the load they can see on a trailer bouncing around....
Richard - no drawing handy but pretty simple. A ring or loop of metal is welded to the outer end of the wheel nut so it protrudes away from the car. Just put the car on the trailer, put one of these thingys on each wheel and go. - Ryan
Whatever you do, don't tie the car straight down unless you are just using over-the-tire straps. The further out the attachment to the trailer, the more freedom the car has to absorb shock. Not to mention teathering for for and aft movement. Longer is better. |
Thanks guys..got a set on the way...
At the last DE I had my new (to me) RS clone and it was incredibly frustrating putting the rear loops into a very tight space..IN THE POURING RAIN! Swore I'd fix the problem before the next DE! The forum, as always, comes thru
