Weight: 3.2 vs 3.6
Anyone know the weight difference between a 3.2 and a 3.6 (with V-ram)? Just wondering if suspension adjustments are required after a conversion to retain corner balance, ride height, etc.
Thanks,
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 09-21-2003, 12:42 PM
drag racing the short bus
dd74's Avatar
Mike: check this thread...
Engine weights
The Terror of Tiny Town
Old 09-21-2003, 12:50 PM
Crusty Conservative
silverc4s's Avatar
3.2 = 482# ; 3.6 = 512 - 525#
Sources are : Achiele, Frere
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 09-21-2003, 12:54 PM
dd:
Thanks! That's exactly what I needed. Carrera 3.2 = 482, 993 3.6 = 512. 30 lb gain.
Mike
Old 09-21-2003, 01:01 PM
Bill Verburg's Avatar
Actually most of the weight difference is in the really heavy 3.6 flywheel/clutch assembly. If you want to compare apples to apples the #s in this thread are the ones you want.
When setup w/ comparable flywheel/clutch assemblys and auxilary equipment the correct #s are
  • 3.2 484#
  • 964RS 497#
  • 993RS 487#
Bill Verburg
Old 09-21-2003, 01:48 PM
Will be using a lightweight FW and a KEP billet pressure plate. Weights should end up pretty close to the same.
Thanks guys,
Mike
Old 09-21-2003, 01:59 PM
Yup, 993 will be a bit lighter than a 964 as well.
Bill Verburg
Old 09-21-2003, 02:18 PM
