Weight: 3.2 vs 3.6
Anyone know the weight difference between a 3.2 and a 3.6 (with V-ram)? Just wondering if suspension adjustments are required after a conversion to retain corner balance, ride height, etc.
Thanks,
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
drag racing the short bus
The Terror of Tiny Town |
Crusty Conservative
3.2 = 482# ; 3.6 = 512 - 525#
Sources are : Achiele, Frere
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
dd:
Thanks! That's exactly what I needed. Carrera 3.2 = 482, 993 3.6 = 512. 30 lb gain.
Actually most of the weight difference is in the really heavy 3.6 flywheel/clutch assembly. If you want to compare apples to apples the #s in this thread are the ones you want.
When setup w/ comparable flywheel/clutch assemblys and auxilary equipment the correct #s are
Will be using a lightweight FW and a KEP billet pressure plate. Weights should end up pretty close to the same.
Thanks guys,
Yup, 993 will be a bit lighter than a 964 as well.
