Luke Hudson's Avatar
2.4 MFI Fuel lines
Hi Guys,
Can anyone tell me what this pipe does? (see arrowed pipe in diagram) I think it's a vapour return tube, but I do not have this on my car (see photo). Also can anyone tell me where the hoses circled in "A" connect up to?
Aubergine 1972 911 2.4E - Gone but not forgotton
HP2S #1185 - Ain't she purty
Resident @ www.ddk-online.com
Old 09-25-2003, 12:16 AM
72 four door's Avatar
Thats what it is luke
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 09-25-2003, 04:54 AM
thanks Paul,
I'll have to fabricate this hose over the weekend.
Does anyone know where the 2 hoses circled "A" above connect too?
Old 09-25-2003, 06:30 AM
Senior Member
Ron,K's Avatar
They connect to the gas tank via tubing that's routed through
the transmission tunnel. You should have two metal fuel lines
protruding just left of the boot that covers the shift coupler.
Ron
69 911T
Old 09-25-2003, 06:34 AM
excellent!, thanks very much Ron
Old 09-25-2003, 06:38 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
That was my impression Ron and I was looking for the diagram that shows it but my machine locked up on me
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-25-2003, 06:39 AM
Tim Walsh's Avatar
I just looked through check measure adjust and it most definitly runs back to the fuel tank. I think it's the return line from injection pump back to the tank. How your car runs without it amazes me.
Tim
1973 911T
2005 VW GTI
Old 09-25-2003, 06:45 AM
i'm pretty surprised it works too, but it does!
I was thinking that maybe the hose that goes to clip 12 (in the circled area) in the diagram could go to the bottom of the airfiler box? i have a small drain pipe at the back of that box. Or would this be a water drain pipe?
Old 09-25-2003, 06:52 AM
Tim Walsh's Avatar
hmm.. I think that should run back to the tank but I don't know for certian.
Tim
1973 911T
2005 VW GTI
Old 09-25-2003, 06:59 AM
there are 2 hoses that come from the tank 1 is the feed [largerhose]2nd is the return
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 09-25-2003, 07:01 AM
Thanks Chaps,
I think i need to spend some time under the car at the weekend and fathom this out. I must have the main fuel lines attached correctly as the car runs and doesn't spray fuel out all over the place. So i just need to work out the routing of this vapour return hose. Can't be too complicated...... famous last words
Old 09-25-2003, 07:06 AM
