911Pete's Avatar
no voltage to coil
I have a 1971 911 T. I dont have 12 volts to my coil. The scematic shows feed from the altenator to the coil via a Intermediate unit. also at this point is the wire to the tach. Can anyone tell me what this intermediate unit is and where it is located. Thanks Pete
Old 09-25-2003, 08:12 AM
The coil is usually called a transformer on the diagrams.
Ground (pulsing) from points in distirbutor to terminal C of CDU on left side wall of engine compartment. Terminal B is 12v dc, D is ground and terminal A will send a 300v dc pulse to tag 15 of the "coil". Blue green on a 72.
There are some good diagrams on this site. Once you understand the 14 pin plugs they are easy to use.
Jeff
'72 911T gone
'85 TVR
Old 09-25-2003, 10:01 PM
911Pete's Avatar
Jeff thanks for your help, tomorrow am when I get home from work I will check it out again. I believe everything is wired correctly. Pete
Old 09-28-2003, 05:12 PM
911Pete's Avatar
New points and cleaned up connections.... she runs
Old 10-03-2003, 07:44 AM
Friend of Warren
We like happy endings!
Kurt V
Old 10-03-2003, 07:45 AM
