nigel911's Avatar
Irregular knock from engine
Pulling in to the drive yesterday waiting for garage door to open when I notice a faint 'knock' from the engine.
Pull car in, open engine bay and listen. Nothing abnormal for a minute or two, then a slight 'knock' which appears to emanate from the 'bottom' of the engine - definitely not from the chain housings (not running oil fed tensioners). The noise is not loud and is very irregular - any ideas? Cheap ideas always preferred over expensive one's...
Old 09-27-2003, 07:19 PM
nigel911's Avatar
Of no relevance but the car had just been filled with gas and had driven through a large Florida downpour on the way home.
Old 09-27-2003, 07:21 PM
Steve W's Avatar
Perhaps crossfire from wet old ignition wires?
Old 09-27-2003, 10:59 PM
nigel911's Avatar
New leads 3 months ago.
Any more before I take it to the spanner?
Old 09-28-2003, 09:36 AM
Cool Re: Irregular knock from engine
Originally posted by nigel911
The noise is not loud and is very irregular - ..
a piston pin knock can be easily diagnoised..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2003, 10:00 AM
