displacement increase for 3.2
question, what is the largest Mahle piston/cylnder combo
available for the 3.2. I don't want to over bore the case
holes either, just install new jugs and pistons along with raceware rod bolts and a fresh valve job and keep the Motronic
Keith Epperly
Old 09-27-2003, 10:00 PM
Diss Member
Quicksilver's Avatar
3.4 (98mm) is the largest straight bolt in. There is a 3.5 (100mm) that requires the case to be bored. Andial is also doing a 3.7 but I'm not sure if that is just a larger bore or if it includes a stroke.
The 3.7 would absolutely require twin plugs. the 3.5 really should have it but you have a choice. (actually a 3.2 benifits from the twin plugs so hey...)
Andial has always been the company with the exclusive distribution but Mahle has a couple other companies ditributing now. I'm not sure if the over sized cans are an Andial exclusive though.
BTW You will need a chip for the 3.4 (and the others).
Wayne
Old 09-27-2003, 10:25 PM
Bill Verburg's Avatar
Here is Andial's Sport p/c page
Bill Verburg
Old 09-28-2003, 08:56 AM
Bill,
Thanks, after Wayne's reply, I had already been to Andials Web site. Wayne I already have an Autoauthority chip, if I go to the 3.4
should I get another one?
Keith
Old 09-28-2003, 03:51 PM
