Super Moderator
PMO Float gauge question
I have a PMO float guage and the instructions say that you adjust to be between the two lines. Prollum is, there are FOUR lines!
I would guess each of the two twin-line bands really represent one line? ...and that the fuel level should be between those two...?
Hello Chris,
i think the two top lines is for weber and the two lower is for zenith carb, ihope i have the good ajusment ... Ray
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
Bird. It's the word...
Chris, Raynald is right. Top meniscus is Weber lower meniscus is Zenith.
Have fun!
John Forcier Current: 68L 2.0 Hotrod - build underway |
Super Moderator
Cool, thanks gents!
Darn directions weren't clear at all! I hope this solves my "Right turn miss". Chris
Chris-
Have you done the float bowl pickup baffle mod already? If you are cutting out in long corners from fuel slosh in the chamber due to the G-force, it may be that baffles are the answer instead of float level, maybe? Also, I think it was Walt Fricke on the Rennlist who once mentioned that some people set the level higher in the bowl which feeds two barrels (I think it's the chamber towards the front of the car, but I'm not positive) vs. the one that feeds only one. Maybe that would help? TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
