Automotive Monomaniac
Emission's Avatar
A/C is getting weak. Do I need to charge it immediately?
My A/C in my '86 is getting weaker and weaker. Just the other day, in ambient 85 degree temps, I needed to crack the window as the A/C wasn't cutting it.
The PO charged the system every two years. It has been about two years since it was last done.
I'd like to wait until Spring to charge it (no use letting it leak all winter). Will this hurt the system? Should I always keep it charged?
How much should I expect to pay?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 10-03-2003, 04:26 PM
scottb's Avatar
The conventional wisdom is that the compressor should be run once per month to keep the seals fresh. Are you running R12 or R134?
1984 Targa
Old 10-03-2003, 04:38 PM
Emission's Avatar
I run it at least a few times a month, even in the winter.
It is R12.
Old 10-03-2003, 04:45 PM
scottb's Avatar
It's not a good idea to run the compressor if the R12 is too low. I'm sure Jim Sims, or one of the a/c gurus on the board, could give you details. Also, if you have a pressure cut-off switch, the compressor won't run when the R12 gets too low.
Since it needs recharging every two years, it sounds like you still have the original hoses. Since cooler weather will be upon us soon, have you considered yanking out the old hoses and installing barrier hoses? I did the work myself, and though it's very messy, it's do-able.
1984 Targa
Old 10-03-2003, 04:52 PM
Since you have an R-12 system I would recommend you have it serviced now. Note the operative word is serviced not just charged. Merely charging or topping off the system runs the risk of having the new charge just leak out again. Also, if your system pressure has reached ambient there is a high likelihood that water has entered the system; R-12 refrigerant and water produce an acid which will internally corrode the A/C components. If the system has been topped off every two years for a while I suspect there is leak that should be addressed plus that a new receiver/drier is in order. A reputable shop will do a leak check of the system and check the compresssor oil situation before adding additional R-12. Expect to pay around $200 plus the cost of the freon (R-12). The cost may be higher if the leak is difficult to find or a new hose or other component is needed. Jim
Old 10-03-2003, 06:53 PM
Carrera Sled's Avatar
Re: A/C is getting weak. Do I need to charge it immediately?
...How much should I expect to pay?
Emission,
85 deg. ambient and you had to open your window a little?? God forbid! I guess in our air-conditioned ruled summers here in the desert I revere fresh air. Pretty soon we'll be below the 100s in the day.
You bring up a good question on the A/C - mine is in the same boat - and it looks like Jim Sims just answered your question. I've been quoted about $75 for replenishing the Freon; but as Jim says it should be leak & oil checked, etc. Good luck.
'85 Carrera Coupe, White Gold Metallic - 8" rear Fuchs, Fittipaldi steering wheel, Weltmeister short shift, Turbo tie rods.
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donohue
Old 10-03-2003, 07:16 PM
Emission's Avatar
Is this a task for a "Porsche" shop, or an "A/C" shop?
Old 10-03-2003, 08:21 PM
bigchillcar's Avatar
Definitely charge the system and run for a couple minutes each month, even when cold.
A nice, clean garage that services a/c should be able to do it. That's where I take mine. Last time I was there the guy didn't even charge me! I wouldn't go so far as to expect that...
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 10-04-2003, 12:02 AM
scottb's Avatar
Emission: I had mine done at Lucas Auto Air in Van Nuys. There's a technician there named Ray Sanchez. He knows P-cars, and did a great job on mine.
1984 Targa
Old 10-04-2003, 05:44 AM
