Montana 911
luck or skill?
Below is a graphic of what happened to me on the way to work yesterday morning. I am not very good with the graphics so don't tease me too much.
I can't help but think how this could have gone wrong...and thet I am really lucky to escape without any damage or injuries since there was morning traffic present (07:30 am). The only thing I really have good to say is I do feel thet since I have spun the car on the track and at Autox events before it helped me stay somewhat calm and not to panic. Could this have been avoided? Yep...I was going just a little too fast for conditions. This a duplicate post from GruppeB Forums
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
"The force is strong in that one..."
Did you just throw your underwear away when you got home? As Jackie Gleason would have said it, "That there's an attention getter..."Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Gon fix it with me hammer
i once had a similar stroke of luck with a Renault Megane 1800 Diesel during heavy traffic when i was doing75mph on a flat piece of highway joining another 3lane highway
i made a perfect 360 inbetween traffic and ended up exactly on the left lane of the other highway. people honking their horn al around me. i thought nobody would believe me at work, but somebody from work was like 150 feet behind me and witnessed the whole thing... in the words of Elvis, i was all shook up
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Driving member
Check your rear tires closely for wear. I spun my car like that about 6 months after I got it. It had just rained a little bit and I turned on to a road at about the same angle as you. As I sped up and shifted into second the rear tires broke loose.
I did a 540 spin and landed in some grass (very lucky). Later I inspected my rear tires and they were worn more than I had realized. Because of the camber on the wheels the wear was a little more to the inside of the tire and since the car sits so low I had not noticed. Needless to say I went out the next week and bought tires
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Montana 911
Jerry, I did go out and inspect the tires for wear...no signs other than normal for tires with 5000 miles on them.
Ryan, yeah the force was with me on this one...and I am not looking forward to any sequals.
Did you let off the gas hard in the corner? That would do it
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Montana 911
Dean, I was not on the gas in the corner at all...I braked before the turn and was allowing the car to just flow through the corner, once the rear started to go I steered into the slide and drifted as much as possible until the rear just went too far to control. I then used the brakes to bring it around and used the steering to avoid the guardrail as in the diagram.
Using the same skinny tires all around is great fun, but not fast.
Glad you are OK.
If you were not on the gas then enterance speed was too fast. In the rain, the whole trick is to be smooth. First complete all braking before the turn. Then gently turn in and apply a small amount of throttle through the turn. Avoid any sudden inputs with the steering wheel. As you exit the curve apply slightly more throttle
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Formerly bb80sc
Wow, scary situation! I had a little slide action the other day transitioning from an off-ramp to the main road. There was a heavy mist and the road was pretty damp. When I felt the back end kick out, I steered into it, then blipped the throttle to get the weight back over the rear tires and it worked out fine.
I'd say you are pretty *lucky* you didn't munge both sides of your car. Be careful out there! -B
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
1.367m later
Having seen what some people can do in far less demanding situations, I'd have to say that there was enough skill involved to be a positive influence on the event. I have little doubt you looked about with your best PeeWee Herman "I meant to do that" look. Glad to hear you escaped without any damage.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Wow, it's great that you and the car are not bent. The only thing that I can think (besides going slower) is that being in the gas a little might have helped since in our cars getting in the gas some transfers more weight to the rear and gives more traction. I think coasting is the low impact equivalent of braking since there is some amount of engine braking.
Non Compos Mentis
Skill, man. Pure skill!
That's my story and I'm sticking with it. |
wow, what a fantastic looking car, i love the yellow, and the contrasting gray ground effects!! so you got off fast and avoided a ticket great work!!
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
I did a similar thing a couple of years ago. In my instance there was a driving November rain and the road surface had layers of fallen leaves which makes the surface very slick. I was running some older Dunlops at the time when the car spun. There may have been just enough oil on the offramp that you described to just allow the rear of your car to break loose. I went out and bought Bridgestone SO-2's shortly after my spin and haven't spun since (knocking on a huge log).
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
SCWDP- Shock and Awe Dept
![]() Glad you got through this one and hope there won't be another. I'm sure skill was a big factor. Be safe!
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
