ignition wires made of gold
Very high quality ignition wire sets for V-8's can be bought for less than $75, why does a set for my 1985 911 cost $200 or more. I need to replace mine soon. What brand does everyone prefer. Has anyone tried making thier own?
Double Trouble
The wires are cheap. It's the resistor ends that are about $15.00 each. Do the math. Yes I have made my own and reused the ends. They worked just fine. But if the ends are shot you MUST PAY.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Friend of Warren
Do a search on here for Magnecor spark plug wires. They are better and cheaper than the OEM wires.
Kurt V No more Porsches, but a revolving number of motorcycles. |
canna change law physics
If you can get them...Took me a month to get a set...When they are in stock, they do not last long.
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Honestly, I can't think of any other reason why they get away with charging such rediculously exorbitant prices which also proves that most Porsche owners have more dollars than sense. I'm currently using a set of Autolite igintion cables (95 Dodge Intrepid 3.5L) on my 86 Carrera 3.2. The deep Autolite spark plug connectors are very high quality and stay well attatched as well as sealing the air around my valve covers better than the Beru's. You can get a whole set at Kragan for $75 with wires long enough to reach #6 cyl. At the distributor end, you'll need to cut off the Intrpid(3.5L) connectors and slide the cables into your stock Beru ends so it will work on the distibutor cap which keeps it looking stock too. Cheers, Joe Garcia 86 Carrera Redwood PCA since 1976 Last edited by stlrj; 09-30-2003 at 12:18 PM.. |
The local/regional wrench demands the $225 wires with shielding.
Windward is emphatic that not only is the shielding not needed but theirs wires are so much better. There are suppliers out there selling plug wires for $150 but are they good. I have been burned by low price suppliers before. Who knows the truth behind all of this. Is the shielding needed? Is an OEM wire a must have (for $225)? I have read all sorts of posts on this but no clear conclusion. |
IMHO, all wire sets perform exactly alike when new. any performance gain is in your head, or the fact that the old wires were toast.
Unoffended by naked girls
$30 Accel 8mm Super Stock spiral wound. Cut off the plug end and screw on the Beru. 1 hour.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Slumlord
dhoward: just buy a V8 set and set use 6 to make sure they're long enough?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
That's exactly what I did. What took the most time was crimping the dizzy terminals, but they supplied a tool for doing that correctly. I found that tapering the jacket on the plug side with a razor knife made the jacket go into the Beru easier for a very tight seal.
YMMV [beavis]"....heh heh. he said tight seal...."[/beavis]
So, the shielding doesn't make a difference?
I have seen, first hand, two Mercedes that had idling and drivabilty problems that went undiagnosed for close to a year. No one could figure the problem out. Turned out that an indy used cheap unshielded wires as opposed to the OEMS....problem solved. While I realize that it 's a different car the computer/ interference relationship makes me wonder. Besides, if your stock ends are fine how much can it cost to buy the OEM shielded wire?
Warren & Ron, may you rest in Peace. |
Slumlord
I don't expect ant interference with my CIS
The braided shield was put in place when Porsche was trying to figure out why the CIS cars kept backfiring and blowing up airboxes. Their thinking was that current was somehow arcing from the wires to the airbox and igniting stray fuel found in the air box. The idea is completely false. One of the times when Porsche completely missed in their thinking.
EMI interference can be an issue but any decent brand of plug wire should be fully EMI-suppressed and work just fine.
gary |
I know mine are better then stock because they are blue.
72 911 Although it is done at the moment, it will never be finished. |
Friend of Warren
Mine are red to match my car!
Author of "101 Projects"
In general, Porsche parts are more expensive because for every part made for a Porsche, there are 1000 made for a domestic V8. Low quantity = higher cost, plain and simple...
BMW parts made by the same manufacturers are much less expensive. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Member
Has anyone been able to source a quality spark plug boot? Bulk wire is certainly available and priced reasonably. Making spark plug wires is not difficult, I just can't find a suitable boot to replace the problematic Beru connectors.
Ron 69 911T |
Navin Johnson
try here
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Is that for real? Sorry, I'm sticking to my $75.00 Intrepid wire set. Joe Last edited by stlrj; 10-03-2003 at 09:31 AM.. |
