Tell me this isn't tempting
I know motor miester sucks but damn thats cheap
Somewhere in the Midwest
3.6 P&C's on a 3.0 case??? Might machining the case open weaken it a bit?
Friend of Warren
While I wouldn't want MM rebuilding my engine. Parts is parts. I wonder if I would have to do any machine work to use these on my 3.2 rebuild. Is is just a bolt on or is there case/head work that needs to be done?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Friend of Warren
As a former customer of MM I know they cut corners. However, if you have the time and don't mind sending stuff back until you get what you paid for, you can get some good used parts - sort of like picking over the cheap 2x4's at Home Depot. The first crank I got from them was horrible (though described as "perfect, ready to go"). I sent it back and the 2nd one they sent was perfect. -Chris
Ross products are very high quality. They are about the same as Probe or Eagle. I'd be more worried about the cylinders.
99.5% possitive feedback???
I had a friend just get his motor back from them after 7.5 months ( I did have fun leaving messages from MM at his work saying we lost your engine, do you have any pictures of your engine parts etc.)! It cost $2800 more than they quoted. He has not put it back in yet...we will see.
01 996TT 2003 M5 1979 930 (sold) BMW 1200 GS Adv&BMW 100/7 F350 Diesel |
They just don't have a good rep with porsches, search, you'll find them. But i was curious, what's the deal with biral cylinders, i thought they were done with after the 2.4's. And doesn't the case need to have it's cylinder bores widened for anything over 98mm pistons?
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
Cool I would like to beta test them, I ll take 10.5 C/R and a cam for carbs please.
Just the tip of the ice burg. Gotta go twin plug I think on that wide a piston and 46mm carbs or after market FI. I wonder if it would work with OE CIS? Ends up being very expensive unless the CIS would work. I think the cylinders are resleeved
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I mean boring the case bores, not the cylinders, to fit the barrels in place?
Platinum Member
They are ebaying both a 2.7>>3.0 conversion and a 3.0>>3.6 kit but using the same picture for both????
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Something about that doesn't sound right. Biral cylinders haven't been used for like 30 some odd years. And in order to go past 98mm pistons with nikasil cylinders, the case bores that hold the barrels must be bored out as i'm aware. And the whole reason Biral was outdated was because originally, you could not go past a 2.4L motor with biral cylinders on the mag cases. When Nikasil/Ausil cylinders were introduced, that when the 2.4's where upgraded to 2.7's. Now if the biggest cylinder you can fit on a 3.0/3.2 case is 98mm to make a 3.2 or 3.5 liter engine without widening the case bores, how the hell do they get 101mm Biral cylinders to fit.
Platinum Member
