Sports Purpose 911 Driver
can an 0/2 sensor be removed...
without using heat? I want to change mine and was curious what you guys had run into.
Thanks --James |
Hilbilly Deluxe
Mine came out with no problem.
Anti-sieze would probably be a good idea, but be really careful not to get it on anything but the threads. Tom |
did you use a socket?
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Hilbilly Deluxe
Nope. One of these:
![]() Tom |
where did you get that image from ?? cool, I will get one, I just thought I might round the nut using one.
thx man.
Mine broke 2 cheap O2 sockets after soaking overnight in PB blaster, and eventually "came out" when I replaced the cat with a premuff. YMMV.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Hilbilly Deluxe
A box end would be better, but the crescent wrench was closer, and I am lazy. Just be carefull and take your time. Tom |
PB Blaster + O2 socket + 20" breaker bar got mine right out in a jiffy.
I soaked mine in PB Blaster, cut the wires and used a long handled box wrench. Came right off.
Argo 88 Targa |
