I ran for the past 18 months without an O2 sensor, but that was also with a test pipe. I put the cat back on Sunday and hooked up the O2 sensor so I didn't run the cat without the sensor. It is possible the sensor damaged the cat I guess.
If the cat was bad would that show up as increased HCs? BTW, I found out from a poster on Rennlist (who works for the Bureau of Automotive repair) that in california if you get designated to go to a test only station and your car fails you are obligated to spend the first $100 to fix it, after that the state will pick up the tab for the next $500. You can bet I'll be taking advantage of that program. |
sammyg2,
A bad cat will have all three elevated, especially if you are running lean. Check the charts I posted above to see how it changes the readings. |
Thanks Harry, that's what I thought. Since the HC and NO readings were reasonably low I assumed the cat was doing it's job, it was just a situation that the mixture went rich at partial load and 2500 rpm and the O2 sensor didn't make the necessary adjustment to control the CO.
I'm going to get this resolved, and not just to pass the test. I want it to run the way it was supposed to run, even if I couldn't tell there was a problem until the smog man told me so. ;) I've been pricing the gunson gas testers, looks like around $150 is the going price. Anyone know of a cheaper source? |
That's a good post, AW.
I can see you're a guy who knows right from Wong. |
Darn internet security thing at work blocked access to that link. I'll have to wait til I get home.
send me your email addy and I will send it right over. Would Word be ok?
From the link above, credited to "William R. Watt"
The following guide is intended to help the owner of a car which has failed an emissions test to understand what may be wrong with the car. Since I am not a mechanic it may contain emissions :-) or errors. If so I'd appreciate comments as it is intended for emailing to peope who post emissions queries in the rec.autos. newsgroups. thanks. ==================================== Emission (smog) test problems. ============================== What to look for when any of CO, HC, NOx too high. CO: rich fuel mixture HC: incomplete combustion NOx: hot combustion and rich fuel mixture CO, HC, and NOx: incomplete exhaust conversion 80%-85% of vehicles pass emissions tests. an in-tune well-maintained vehicle should pass. allowances are made for the age of the vehicle. for the rest some details are provded below. note that both CO and HC rise in the absence of O2 (oxygen) in combustion and in exhaust, and that NOx rises in the abscence of O2 at high combustion temperature. HC also rises when there is too much O2 in combustion. 1. CO (carbon monoxide) too high. --------------------------------- causes: a) not enough air (oxygen) in air/fuel mixture to make carbon dioxide (CO2) so get carbon monoxide (CO) instead (mixture too rich). can be too little air or too much fuel in mixture. b) not enough air (oxygen) in exhaust system to convert CO to CO2 c) faulty catalytic converter. look for: a) too little air - dirty air filter, stuck choke, plugged or sticking PCV or EGR system, plugged carbuettor or injector air passage b) too much fuel - carburettor or fuel injection system supplying too much fuel c) too little air or too much fuel - engine control system - vacuum hoses, sensors (eg exhaust oxygen, temperature, air flow), computer, actuators (eg fuel metering solenoid, air metering solenoids), wires and connections (control system voltages are so low that small resistances from dirty or loose connections make a big difference), the computer uses the input from the sensors to send signals to the actuators to keep the air/fuel mixture at the optimum for power, fuel efficiency, and low emissions. d) too little air in exhaust system - restricted outside air feed to converter (eg air pump or pulse air system - hoses, electrical connections, valve, pump, drive belt, sensors) 2. HC (hydrocarbons, ie unburned fuel) too high. ------------------------------------------------ causes: a) not enough oxygen in combustion to burn all the fuel, or too much fuel (mixture too rich), so excess fuel blows out exhaust. b) too much oxygen in combustion or too little fuel (mixture too lean) for uninterrupted combustion (engine misses), so unburned fuel blows out exhaust. c) sparkplugs not firing properly to ignite air/fuel mixture (ignition system), so unburned fuel blows out exhaust. d) combustion chamber too cold for complete combustion, so unburned fuel blows out exhaust. e) combustion chamber hot spots preventing complete combustion, so unburned fuel blows out exhaust. f) not enough air (oxygen) in exhaust system to convert HC to H2O and CO2. g) faulty catalytic converter. note that HC in exhaust can combine with S (sulphur) from fuel to produce rotten egg smell. look for: --------- a) mixture too rich - see a,b,c in CO section above. note that if HC is too high but CO is okay then the problem is not a rich mixture. b) too much oxygen in combustion - leaks of air (hoses, gaskets) and routing of hoses into intake manifold, leaks in EGR and PCV valves c) too little fuel - dirt in fuel/filtre/tank/lines, leaks in fuel lines or connections, weak fuel pump, - mechnical problems in carburettor (dirty valves or passages or linkages, worn parts or gaskets) or fuel injection system d) too much air or too little fuel - computer not mixing air and fuel properly (see c in CO section above) d) ignition system - sparkplugs fouled (type of fouling may indicate problem), poor contact or insulation in high voltage ignition wires or in distributor (cap, rotor), poor contact in coil wires, low voltage in charging system (alternator, regulator), faulty transistorized ignition control module e) combustion chamber too cold - sticking EGR valve or sitcking cylinder exhaust valve or bad cylinder valve timming letting "cooler" exhaust gas into the combustion chamber. f) combustion chamber hot spots - bits of junk (dirt, carbon) or nicked or burned metal parts glowing red hot in combustion chamber and igniting air/fuel mixture (engine misses) - can use chemical cleaner in combustion chamber or take engine out on the highway or both to burn off junk - overhaul engine to remove nicked or burned metal parts or hardened junk g) too little air in exhaust system - see d in CO section above. 3. NOx (oxides of nitrogen) too high: ------------------------------------- causes: a) too much heat in combustion chamber - air contains about 78% N2 (nitrogen gas) which becomes chemically unstable above 2500 def F and combines with O2 (oxygen, making up about 21% of air) to form NO which, released into the atmosphere, forms NO2 which in the presence of sunlight combines with HC (hydrocarbons) to form smog. note that NOx only happens when engine is under load (car at crusing speed on road or rollers). b) too much CO in exhaust (CO enhances the conversion of NO to NO2). look for: a) too much heat in combustion chamber - the EGR system or the valve timing is used to bring exhaust gas back into the combustion chamber to cool it off when the engine is hot under load at cruising speed - check the EGR system valves, solenoids, wiring, hoses - if the car does not have an EGR system check valve timing - (engine cooling (water) and lubricating (oil) systems may have some effect on combustion chamber temperature?) b) computerized engine control system - adjusts engine operation to minimize emissions (see c in CO section above). ---------------------------------------------------------------- sources: "Automechanics" (Prentice-Hall, 1988) "Import Car Manual 1983-1990" (Chilton, 1989) |
| All times are GMT -8. The time now is 03:38 AM. |
