byrd101's Avatar
Any one capable of doing an alignment in Sarasota FL?
I have a 71T, and have recently rebuilt the suspension. New bushings, tie-rods, ball joints, struts and torsion bars. I’ve added a front sway bar and camber bar. I have the ride height set at 25 1/2” front and 25 ¼” for the rear. Now if only I can find someone capable of doing an alignment. I have taken it to two different shops. The first lowered it (23 1/2” Front and rear) and then said it must have been hit at some point, because they couldn’t get the camber correct. Call me crazy, but I thought the finders rubbing on the rear tires was a dead give away. The tech at the second shop swore up and down “Not a problem we do’em all the time”. Then he airs up the tires to 36psi. During the subsequent conversation I describe the suspension upgrades that had been done. “Ugh, I can check the rear, but I don’t have the tools to make any changes”
Old 10-16-2003, 12:45 PM
MBruns for President
JeremyD's Avatar
If it's worth a trip across the big bridge Joe at Germantech does a good job for me - www.germantech.com nice guy too.
Old 10-16-2003, 02:02 PM
nigel911's Avatar
Who did you use? Scottshop recommended D&W tire when I did roughly the same kit out as you, I only had the front end aligned but I do know they can do both ends. 2856 Clark Road, 922 5544.
Is you car a green coupe?
Old 10-16-2003, 04:04 PM
byrd101's Avatar
No,white. Thanks for the tip.
Old 10-16-2003, 06:27 PM
JeremyD's Avatar
byrd101 - PM me your email and I'll make sure to add you to our email list. When we have another get together you and Nigel can caravan over. Maybe you can print out the directions!
Old 10-16-2003, 07:37 PM
nigel911's Avatar
Jeremy, I believe you are truly evil.
All this time since your move across the pond and you still haven't lost your sense of humour...
Old 10-17-2003, 02:51 PM
Armond of Eurosport in Cape Coral. His specialty is Porsche. He can help you out.
Old 10-17-2003, 05:23 PM
JeremyD's Avatar
Hey, there's Nigel... there he goes.........................
Old 10-17-2003, 06:22 PM
