Power Window Issue
Hey All,
I have a weird power window prob. The driver's side will occasionally stop working in the fully closed position only, never down or partially down. I found that if I use an allen wrench and manually work the window even a tiny amount it will work perfectly for a few months then, totally without warning, stick in the totally closed position till I wiggle the gear a bit.
Any ideas?
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-16-2003, 08:03 PM
I had a similiar problem with my power window. It would ocassionally quit working in the down position. I replaced the switch and it has worked flawlessly ever since.
Roger
1980 911 SC
Old 10-16-2003, 08:14 PM
Had a similar problem with my '88. Driver window hung up and wouldnt work at all. Took the door panel off and rapped the motor with a screwdriver and it started working!! Figured the brushes hung up... Sounds like you might have a bad spot on the commutator.
When the motor stops in the bad spot it wont work, a small movement to a 'good' spot gets it going again.
I took the motor off and cleaned up the brush rigging and its been working fine since.
YMMV :} Joe
flat 6's..
'88 911 targa --> fast
'61 BE35 -> faster - but sold ;{
Old 10-16-2003, 10:47 PM
That sounds like a likely solution. It seems to have a bad spot that it gets no power. I'll try that this weekend.
Thanks!
Buck
'88 Coupe, '87 Cab,
Old 10-17-2003, 07:34 AM
GFCC
Jeff's Avatar
Buck, you may try spaying the switch with contact cleaner. It is worth a shot before having to take the motor out.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 10-17-2003, 07:55 AM
