FPH Gruppe
Skip Newsom's Avatar
Question Sand blasted Valve covers- cause for concern?
I'm begining my winter P-car projects and upgrading to turbo valve covers on the lower sides is first up.
I ran a heavy dose of techron through, drained the oil, set valves (all were loose, hope i picked up a couple of ponies) and sand blasted the top covers as well as the new turbo lowers I picked up from our host... I decided to have them all powder coated as close to the signal yellow body color as possible.
While inspecting the top ones I found a small crack.
So the question is, do I continue and powder coat, or do I replace the top covers too???
The crack only goes about 1/3 of the way through the cover...
Skip Newsom
72 911T Targa
Signal Yellow
Now sporting a big Port 3.0 built by THE John Walker
Old 10-18-2003, 06:26 PM
Friend of Warren
No question that crack is going to get worse. Get new ones, they aren't that expensive.
Kurt V
Old 10-18-2003, 06:32 PM
mr914's Avatar
If you have a buddy that is a machinist. I'd tig weld it and mill it smooth.
No machinist buddy (6-pack standard), buy a new one.
Never enough time to be doing the fun stuff.
'70 914-6 2.2 MFI #269
'71 914-4 2.0
'85 911 Carrera
Old 10-18-2003, 06:46 PM
Randy Webb's Avatar
get some from eBay. But if/when it fails it won't be a catastrophe.
Old 10-18-2003, 07:22 PM
maxnine11's Avatar
not affiliated etc. etc. used valve cover auction
max
max
Old 10-18-2003, 07:40 PM
makaio's Avatar
I second picking up one or a set from e-bay. I've seen them go for under $10 a piece.
JB Weld? Maybe someone could explain why that would not work...
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-18-2003, 07:55 PM
I just bought a new set of upper valve covers for my 75 911 rebulid. Cost me $300 at Porsche. The old ones were not flat, which is the problem with buying used ones sight unseen.
1975 911 Carrera BLK/BLK
Old 10-19-2003, 04:46 AM
makaio's Avatar
To flatten them, you just need a sheet of 180 or 220 wet/dry sandpaper and a very flat surface.
Old 10-19-2003, 06:13 AM
Irrationally exuberant
ChrisBennet's Avatar
Looks like someone cracked when overtightening them. As long as they're flat I don't think it will leak. The top covers only get exposed to a mist of oil - they don't have sitting oil on the seam like the bottom overs. Even if it cracked all the way through I'd just make sure the crack was on the high side of the valve cover. The nuts only need to be tightened to about 7 ft/lbs. Call me frugal. Replace the covers if and when they leak.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-19-2003, 08:56 AM
FPH Gruppe
I welcome the input!
I'm pretty frugal too and because it's an upper cover, still nice and flat, plus away from the area that actually needs sealing I'm on the fence about replacement.
Pelican has turbo uppers for $137.50 each! ouch, that would cut right into my carpeting budget...
Skip Newsom
72 911T Targa
Signal Yellow
Old 10-19-2003, 02:32 PM
350HP930's Avatar
If the crack is only from the hole to the outer edge of the cover I would just give them a light filing to make sure they are flat and use em.
Old 10-19-2003, 02:39 PM
Early_S_Man's Avatar
Porsche Crest
Skip,
I would replace your Mg top covers with new aluminum covers as I did. The problem with used is you never know the condition, and risk getting a set of junk parts!
The new upper covers weren't called 'turbo' covers in my recollection, and they were only $48 or so, each, about six years ago.
My reason to replace the Mg ones was strictly due to the difficulty in painting Mg!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-19-2003, 02:48 PM
You do not have permissi
john70t's Avatar
88911coupe: JB weld melts with heat and couldn't stick to the expanding/contracting surfaces I guess. I patched a cracked radiator with JBweld and fiberglass mesh but it only lasted a month or so.
Old 10-19-2003, 02:51 PM
Team California
speeder's Avatar
That is a nothing crack in a nothing place, plenty of meat left there. Just don't overtighten them and you will be fine for another 50 years. Top covers never leak, and if they do it isn't much.
AFAIK, there is no such thing as "turbo" upper valve covers, turbos use the same upper covers as all nine elevens, and used are as good as new if not damaged. Should be $10-$20 each.
Denis
Old 10-19-2003, 04:19 PM
