rboylan's Avatar
Help w/correct way to remove this Blaupunkt(pic)!
Guys,
What is the correct method for removing this factory Blaupunkt. As you can see each side has 2 small holes at the top and bottom and a vertical slit between them.
Correct removal suggestions would be great. Thanks guys.
2014 911 GT3
1979 930 Turbo
1970 911T
2016 Cayman
2019 Macan
Old 10-19-2003, 12:38 PM
one of gods prototypes
bell's Avatar
the 4 holes on the radio (2 left/2 right) have retaining clips in them
cut a coat hanger into 2 small u's and stick on in on the left/right......
apply pressure sideways outward from center on both and then reach under and push from the rear.....the clips are about 3/4" in the hole.....
then it'll slide right out.
Brought to you by Carl's Jr.
Old 10-19-2003, 12:42 PM
