Help w/correct way to remove this Blaupunkt(pic)!
Guys,
What is the correct method for removing this factory Blaupunkt. As you can see each side has 2 small holes at the top and bottom and a vertical slit between them. Correct removal suggestions would be great. Thanks guys.
1969 911E Albert Blue 1970 911E Iris Blue 1970 911T Signal Orange 1972 911T Gold Metallic 1981 930 Arctic Blue 1981 930 BB Auto(on ship) 1987 930 Cassis Red Met 1996 993TT Black 2007 997TT Cobalt 2017 991 Turbo Cab |
one of gods prototypes
the 4 holes on the radio (2 left/2 right) have retaining clips in them
cut a coat hanger into 2 small u's and stick on in on the left/right...... apply pressure sideways outward from center on both and then reach under and push from the rear.....the clips are about 3/4" in the hole..... then it'll slide right out.
Brought to you by Carl's Jr. |
