jk911's Avatar
Question How can you tell an SC engine from a 2.7 ?
When looking at a 911 at an auction and you have no details but a visual inspection of the car how can you confirm that the engine in a 74 has been replaced with a 3.0 L. Is a red sroud a reliable indicator. There are many listings for 2.7 engine numbers but I can't find any for 3.0 L engines ?
Old 10-22-2003, 10:03 PM
Bird. It's the word...
Fishcop's Avatar
John, I'm pretty sure SC is when Aluminium crankcases returned. These cases are generally brighter than the dark grey magnesium of the 2.7
Anybody else?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-22-2003, 10:18 PM
Hilbilly Deluxe
emcon5's Avatar
Old 10-22-2003, 10:20 PM
jk911's Avatar
emcon5, legend ! Thank you Very much ! You just answered all my questions thanks!
Actually all but one ... I know where the engine number is stamped on the engine but where is the engine type stamped ?
Old 10-22-2003, 10:33 PM
Irrationally exuberant
ChrisBennet's Avatar
Look at the floor under the rear of the car. The 2.7's will generally leak more...
(I'm ducking for cover!),
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-23-2003, 05:04 AM
Senior Member
Doug Zielke's Avatar
And, I might add, they..... last!
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 10-23-2003, 06:46 AM
Send a message via AIM to fintstone
Rt side near fan-just under oil pressure sender
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-23-2003, 10:16 AM
MT912RS's Avatar
If it actually running you could probably come up with a statistical method for determining if it is a 2.7 or a 3.0 weighing in area of the oilspot, smoke volume from exhaust, # of head studs rattling, year of car it is in,.......etc. Or you could look to see what the case is made of.
Old 10-23-2003, 10:22 AM
