Seldom Seen Member
Burnin' oil's Avatar
I suffer from oil leaks
but enough about me . . .
My '73 leaks oil on both sides, but primarily on the driver's side. I have replaced the lower covers with turbo covers and have gone through various permutations of gaskets and torque. I even had the new covers re-surfaced. Even though the oil appears to be coming from the lower covers, I have ruled that out by my meticulous craftsmanship.
My question, to which I desire a unanimous and definitive response, is "Do upper covers leak?" And if so, why are the upper upgraded covers so expensive? And, after reading the Olsen article in GQ, I would like him to buy them for me.
Thank you.
Old 11-10-2003, 07:14 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Yes and you have Mag uppers and they are prone to leakage. Try to find a set of used Alum ones, or buy new. steve
Old 11-10-2003, 07:50 PM
SteveF_911's Avatar
Don't forget to check the rocker shaft are not the cause.
I put in the RSR seals, no problems since.
66 911 with S engine
2008 Westfield XTR2
Old 11-10-2003, 07:55 PM
Send a message via AIM to fintstone
Lots of leaks that look like they are from the lower valve covers, but are not! Degrease your engine and get under it while it is running until you are sure.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-10-2003, 07:56 PM
ditto
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-10-2003, 08:58 PM
AFJuvat's Avatar
Yes uppers leak, but you will usually see oil in the tin, or it tends to run towards the pack of the motor and drip out there.
Would recommend degreasing and looking carefully for leaks - some UV dye in the oil and a black light do wonders for finding wandering leaks in 911 engines
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-10-2003, 09:03 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Yeah, me too. Wanna compare Harley's?
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-10-2003, 11:08 PM
Author of "101 Projects"
Wayne 962's Avatar
Typically, you can see the upper valve covers leaking, so it's easy to rule them out. More likely may be the interface between the heads and the cam towers. Clean the area off really well, and then start the engine. You also may want to use some dye too...
-Wayne
Old 11-10-2003, 11:18 PM
Administrator
Jack Olsen's Avatar
And typically, I don't pay for anyone's valve covers but my own.
Old 11-11-2003, 12:02 AM
Send a message via Yahoo to FRED/LI
Run your finger under and along the uppers lower edge. You can use a white glove and pretend you're a concours judge. They do this trick when they can't find enough faults.
Fred '95 Carrera2. Previous: '69S, '79SC, '84Carrera, '90 C2, 20+ years and counting......
Old 11-11-2003, 03:30 AM
Seldom Seen Member
Thanks for the input.
Why do things that happen to white trash always happen to me?
Got nachos?
Old 11-11-2003, 08:22 AM
