3.2 Carrera Front Wheel Noise - help!!!!!
I hope someone can identify this with the vague description I am about to give. About 5 years ago after a long drive I would hear a resonant whining sound from one of the front wheels accompanied by vibration in the steering column.
Well now its terrible and happens after a few miles of driving. I've had calipers freed, a wheel bearing changed and the last time a "specialist" drove it he said it also sounded like brakes binding and supposedly freed the calipers on one side again.
200 yards away from the garage and it is no different
What I can say is that it sometimes goes away temporarily if I steer sharply or if I brake.
A hearty thanks to anyone who has "been there" or knows what I'm talking about.
Old 10-28-2003, 04:13 AM
dickster's Avatar
as a starting point, lift the front of the car off the floor. apply the foot brake hard and then release.
now try and rotate the front wheels. any noise? do they move freely?
any noise heard in this state should be either brakes or bearings.
well?
Rich
'86 coupe
"there you are"
Old 10-28-2003, 06:06 AM
Thanks dickster. Is there a place where I can use a hydraulic jack to pick up the entire front?
Old 10-28-2003, 06:15 AM
MBruns for President
JeremyD's Avatar
Sounds like a stuck or sticking brake caliper or a rotor that is warped to me. Especially if it goes away when steering or braking.
Old 10-28-2003, 06:23 AM
dickster's Avatar
mmmm, good question!
i believe (its been awhile) that if you jack up using the front wishbone mount (where tow eye is attached) on either side, it will lift the whole front. if not do one then other.
Rich
'86 coupe
"there you are"
Old 10-28-2003, 06:24 AM
Roy M's Avatar
It's your caliper - been there done that. No good just freeing them up - get a couple of rebuild kits (about £10 each) and a couple of new flexi hoses (about £9 each) and rebuild them - easy job and very satisfying when it all goes back together and solves the problem!
Dickster - congratulations on the new arrival
Roy
Old 10-28-2003, 06:33 AM
targa911man's Avatar
Same symptoms recently and upon exam found a hanging puck. Put new seals in the front calipers over the weekend with the aid of kstylianos and no more noise. (Also replaced the pads & rotors, which probably didn't hurt.)
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 10-28-2003, 07:34 AM
85Gold's Avatar
Also if you do the calipers I would also replace the wheel bearings and seals. Inexpensive peace of mind.
Peter
2005 GT3 Black SCCA Solo 2 SS
1999 M Coupe SCCA SM2
2001 Mazda Miata (Wife's Ride)
2005 F150 FX4 + Trailex
Old 10-28-2003, 08:04 AM
You guys are amazing. The power of a forum!
Many thanks.
'86 3.2 Cab
Old 10-28-2003, 08:33 AM
dickster's Avatar
lifting front with floor jack
Rich
'86 coupe
"there you are"
Old 10-28-2003, 08:38 AM
If you replace the wheel bearings and seals, shouldn't you also replace the races? Requires a press to remove and install. Correct me if I'm wrong...
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 10-28-2003, 08:45 AM
dickster's Avatar
ok, press not required
Rich
'86 coupe
"there you are"
Old 10-28-2003, 08:48 AM
VenezianBlau 87's Avatar
When someone says "replace the wheel bearings" that includes the races. They're matched and come in the same package. As part of my recently completed front suspension rebuild, I tapped out the old races with a rounded end center punch; after heating in my barbeque grill. Gentle tapping into the little divits in the hub is all it took.
The new races went back in beautifully, after heating, with the bearing race driver set recommended by KTL (Kevin). $30 Lisle brand from PepBoys. Two of the drivers in the set are perfectly sized for inner and outer races.
Bob
Bob S.
'87 911 ("Hardtop" per neighbor)
Old 10-28-2003, 12:01 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Thumbs up
Rock on Bob.
That Lisle race driver kit works excellent and is pretty decent quality for $30, no? Those ice cold races go right into the warm hubs nice and smooth!
Good call on the BBQ grill. Hadn't thought of that. Might keep some of the other fellas from getting yelled at by the wife (car parts in the oven).
Kevin L
'86 Carrera "Larry"
Old 10-28-2003, 12:12 PM
Send a message via ICQ to old_skul
Can someone explain this "race driver" to me? I'm confused. I need to replace my front bearings as my fronts are starting to moan a little.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 11-10-2003, 07:27 AM
They come in a kit. There are several different sized disks that screw on to the handle/driver. You pick a disk that is big enough to drive the race but small enough to not scrape the inside of the hub. Charlie Stylianos (kstylianos) can tell you where he got his set.
Dan Morissette
Old 11-10-2003, 09:04 AM
skul--
I should add that if it's moaning you're hearing, IMO its more likely a warped rotor or hanging puck that's causing it, although you probably will want to both change the bearings and service the calipers. That's what I did.
Dan Morissette
Old 11-10-2003, 09:08 AM
