Cab Stiffening Idea
I've had a couple of ideas for stiffening up my cab, and was too lazy to go to the gym tonight, so I executed one of them.
Basically it's a simple bar that goes between where the seat belt retractors used to be. It's .125 square mild steel tubing - just had it laying around. I chose this over round stock so I can make a shelf out of it, ala RS America. I had to cut the support in half and weld it in the car, because I couldn't get it in otherwise. Next I'll figure a way to tie it into the roll bar, but I want to keep the roll bar removable. I'm also not 100% certain that's the best way to route the belts. Before I put this brace in, I could push on the area by the stock cab belt mount and visibly move the body and make it squeak. Not any more!
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
You are just a fabricating machine! Cool! Any progress or more ideas for the door bar?
Administrator
I clicked on the subject, expecting to see this, again:
![]() But that's good work, Thom.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Information Junky
I'm having a hard time trying to imagine how that sqr tubing is going to add any meaningful stiffness.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Hey...they used my car for that ad.
My car gets it stiff enough already... but I like the ideas if I were ever to track it. |
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
B58/732
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Mike
RETIRED
A squeak is a flex...no squeaky, no flexy.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
The goal is to reduce longitudinal flex, which results in squeaking among other things. I've accomplished this to a degree. As part of my test last night, I did some speed bumps, and noticed that I don't get as much shake when the last wheel comes down off the bump.
The other changes I noticed are a more solid sound and feel when I close the doors, and now the passenger-side window is no longer aligned perfectly with the top rubber - I'd spent hours getting that right. In hindsight, maybe I should have done the welding with the top up... So yes, I added a few pounds, but I think I improved the overall stiffness of the chassis. Is the tradeoff worth it? We'll find out on 11/9 when I take it to Sears Point. (edited for spelink)
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs Last edited by widebody911; 10-30-2003 at 09:08 AM.. |
Thom:
You indeed may have improved the rigidity...but I tend to agree with the voices that say a cross brace will do less improvement than the lack of stiffness in the longitudinal door area. Look at your car from a distance from the side....open the doors...and you'll see what I mean. Not as bad as a 914, which looks like a pair of boxes connected by floor sheet metal when viewed this way. My point? the same amount of steel and weight...applied in some fashion along the length ( not width) of the car...especially in the door opening area..may have served you better. BTW... I saw earlier threads on such mods you were proposing, so what happened? Probably interefered with "streetability" too much, I would imagine. ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I have a friend who's a CE that builds his own offroad race cars. When we both get some time free, we're going to sit down and evaluate my chassis and how I can strengthen it without adding too much material. Oh, and he has a hydraulic tubing bender that he wants to 'store' in my new shop to clear some space in his garage
Thom:
An "X" brace in the door....but asymmetrical...may work. More like a "U" on top of another, but upside down "U". Leaves a wide space for legs to swing over. Not as efficient as a pure "X", but triangulating the front and rear edges of the door-openings will do a *lot*. ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 10-30-2003 at 12:08 PM.. |
To Stiffen it up you need to weld in a sister inner rocker. This the piece the factory installs on all cabs and targas.
# 911.501.962.46 and 911.501.961.46
Racing Porsche for over 30 years. http://www.OttosVenice.com Check out the Porsche Owners Club Track event Videos |
Time for a coupe.
time for a full cage...and a carbon fiber roof
Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
I think The Racers Group has them,
I assume you are refering to the roof? Jim
B58/732
I think Thom's end goal is this:
I want to see the rest of that car. I dig vintage cars!
