MSD for '79 Turbo Rookie Questions
Will the MSD 6AL/MSD Coil work on an otherwise stock '79 930? Will the over boost switch and run on relay still operate?
Does the 20 degrees of spark cause detonation problems?
Anyone running this ignition on a Turbo?
Thanks,
DLG
Old 10-30-2003, 07:58 PM
bb bb is offline
I am going to hook up the msd 6btm(w/boos control) in the next couple of weeks. I am also going to use the MSD timing box so that the msd will run the whole thing. It is going into my 2.7 Turbo.
Oscar
Old 10-30-2003, 08:12 PM
I have had the MSD setup on my car for 2 years. No problems. The overboost sw. is not related so it works and I assume the run on relay would work also but I don't have one. The only hard part is fitting the unit in.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-31-2003, 04:15 AM
Dept store Quartermaster
lendaddy's Avatar
I run an MSD 6AL with blasterII coil. No problems.
Cornpoppin' Pony Soldier
Old 10-31-2003, 05:08 AM
