Location: Seale, Alabama (25 miles south of Auburn, Al.)
Wipers cycle when I "Flash Brights"
Each time I pull back on the arm to flash my brights my wipers cycle once and then turn off. How do I stop this?
Also , my headlights will go to highbeam on "flash" but will not change to highbeam by pushing the stick forward. I think there is some contacts on the stick that I need to "bend" Help Rick
Red 1977 911s 3.0L (27230) 2013 Base Cayenne 3.6L |
burp,
yep, you MAY be able to bend the contacts in the wiper switch, but if you don't install a relay kit at the same time you will be better off replacing the switch. I think Pelican has it for about $75. You'll need to pull the steering wheel to bend or to replace switch.
You will be better off replacing the switch.
